09-12-2018, 01:38 PM | #1 |
9785 airtex fuel pump
The box says it's for an 8ba, but will it work fine on a 59ab? I see the inlet hose will be at a different angle and the shape of the gasket varies a bit. Thanks.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
09-12-2018, 02:19 PM | #2 |
Re: 9785 airtex fuel pump
If it says made in China, go get your money back.
Sal |
09-12-2018, 03:30 PM | #3 |
It will work on an earlier engine, you may have to rotate the top to get the lines in the right place.
09-12-2018, 07:46 PM | #4 |
Well the box says 'Made in USA' and it looks to be of high quality. I never dreamed of rotating the top, but doing so made both connections clocked like the 59ab pump, so I proceded to install it. Unfortunately with the pump stand that's on this engine, there is not room for the shape of the 9785 mounting surface to mate up. It looks like a person could grind or saw the casting of the late model pump and it would mate up, but since it's not an emergency repair, I opted to wait for another correct pump. I do after all, have one truck with an 8ba and it can be a spare for that. I know I could have adapted it if I really had to because there is enough flat milled onto the necessary surfaces. Thanks guys.
09-13-2018, 06:24 AM | #5 |
