Old 11-06-2017, 01:44 AM   #1
IndianapolisRacer
Default Radiator for my 1939 Ford
My 1939 Ford has a 1948 Mercury engine in it and is cooled with the original 1939 non pressurized radiator and in addition the fan is mounted on the lower pulley so I need a good pressurized radiator with an electric cooling fan . What is the best combination and where do you recommend to get it . Thanks
IndianapolisRacer is offline   Reply With Quote
Old 11-06-2017, 09:47 AM   #2
fourtydlx
fourtydlx's Avatar
Send a message via Yahoo to fourtydlx
Default Re: Radiator for my 1939 Ford
walker
fourtydlx is offline   Reply With Quote
Old 11-06-2017, 09:55 AM   #3
RKS.PA
RKS.PA's Avatar
2X on Walker. A little more expensive, but well made.
RKS.PA is offline   Reply With Quote
Old 11-06-2017, 10:13 AM   #4
Juergen
If you indeed have the original radiator and it is in good shape, Skip Haney sells a 4 pound pressure valve that attaches to the bottom of your existing radiator which would solve your pressure problem. And an alternative to the electric fan, you could change to a 37-39 standard generator with a top mounted fan (a lot easier if the radiator is original and has the dome underneath it to allow for tightening the generator).
Juergen is offline   Reply With Quote
Old 11-06-2017, 11:09 AM   #5
40cpe
40cpe's Avatar
Is your '39 a Standard or DeLuxe?
Old 11-06-2017, 11:28 AM   #6
19Fordy
19Fordy's Avatar
I installed a Walker in my 40 in 1999 and it has given me zero problems. Be sure to tell them the size of your upper and lower hose connections, just to be sure. They will change the size if you want. They also sell a shroud.Best to call them and explain your situation.
Old 11-06-2017, 12:16 PM   #7
IndianapolisRacer
Car is a deluxe coupe with 3 Stromberg 97s , Offy heads ect
Old 11-06-2017, 12:18 PM   #8
IndianapolisRacer
Thank you I will contact Walker , car does not over heat on open road but when in traffic gets hot !
Old 11-06-2017, 12:20 PM   #9
IndianapolisRacer
I understand but I have 3 Strombergs so no room for high gen/fan combo .
Old 11-06-2017, 12:34 PM   #10
40cpe
40cpe's Avatar
I'm using a Cooling Components fan on my '38. I have it on a thermo switch in the head that turns it on at 195 and off at 180. It cycled on/off on the hottest Mississippi days this summer. It is quiet, too. I'm running a stock, clean, 4-row original radiator. The only negative I can say is that the shroud blocks some natural air flow so the fan still cycles at road speeds.
Old 11-06-2017, 12:56 PM   #11
51504bat
51504bat's Avatar
I'm running a Brass Works in my '39 with an 8ba. Cools fine and I'm very happy with it. Lee will discuss your particular situation and build you exactly what you need. JMO.
Old 11-06-2017, 02:20 PM   #12
flatheadmurre
flatheadmurre's Avatar
That means the radiator is ok.
You need to fit a shroud to improve flow standing still or an electrical fan.
Same issues will be still there with a new radiator so plan for a shroud or electrical fan ahead of the swap.
Old 11-06-2017, 06:47 PM   #13
IndianapolisRacer
Thank you for advise .
Old 11-06-2017, 09:49 PM   #14
flatjack9
flatjack9's Avatar
That is exactly what I did on my 39. The shroud cured the overheating in traffic.
Old 01-30-2018, 08:57 PM   #15
IndianapolisRacer
What radiator cap are you using 3#, 4#. 7# ect
Old 01-31-2018, 08:20 AM   #16
47Merc
I'm using one of these in my 40 coupe with a 47 Merc motor and it runs cool, even in the heat we get here in Australia. I dont have thermostats fitted but I installed the 40 bottom pulley and use the original 40 fan.
I even had to fit an extra VDO temp gauge because I couldn't believe the low reading I was getting on the stock gauge. Turned out it was right.
https://www.ebay.com/itm/CHAMPION-3-...9aX0qu&vxp=mtr
47Merc is offline   Reply With Quote
Old 01-31-2018, 09:31 AM   #17
19Fordy
19Fordy's Avatar
I am using a 10 pound cap from Walker. I made my bottom hoses out of copper tubing and then chrome plated it. Top hoses are out aluminum. Goal was to eliminate as much rubber hose as possible.
Old 01-31-2018, 10:09 AM   #18
flatjack9
flatjack9's Avatar
I have no pressure cap on my stock 39 radiator.
Old 01-31-2018, 10:29 AM   #19
Charlie ny
Indy,
I go with flatjack.......I'm real happy with my stock rad and Walker shroud
on my '41 1/2 ton, same rad and fan setup as yours. 264" '49 Merc, big compression,
Max 1 cam and ancient Rochester 4 brl. Zero pressure don't even tighten the cap.
I will admit it was Jack who steered me away from an elect fan or new rad...
thank you sir.
Charlie ny
Old 11-12-2019, 05:18 PM   #20
Jeff Cassell
I need a 39 Radiator for a Deluxe. Want to sell it? Jeff 817-988-7653
Jeff Cassell is offline   Reply With Quote
