Old 10-16-2019, 01:07 AM   #1
coachstaff
Default Radiator
Suffering from brain failure again. I just purchased a 1931 Victoria and it has been idle for over 40 years. The radiator has rust colored coolant when I drained it. Any suggestion on my next step?
coachstaff is offline   Reply With Quote
Old 10-16-2019, 03:45 AM   #2
johnbuckley
johnbuckley's Avatar
Default Re: Radiator
Step one : fill with water see if it leaks. step 2 if no leaks do a search on this forum for cleaning radiator
Old 10-16-2019, 11:24 AM   #3
Cape Codder
Cape Codder's Avatar
I have used Simple Green in the cooling system and ran it for a short period of time. I then back flushed it with clean water with good results.
Cape Codder is offline   Reply With Quote
Old 10-16-2019, 12:59 PM   #4
1931 flamingo
1931 flamingo's Avatar
WELCOME Depending on where you are, it's starting to get COLD. Make sure you've got all the water out of the rad and block.
Paul in CT
Many ways to clean: Simple green, vinegar, EvapoRust, CLR, etc There's a search function above and this subject has been covered multiple times,
Old 10-16-2019, 01:17 PM   #5
Charlie Stephens
Remove the plugs, add some oil to the cylinders through the plug holes, and turn the engine over by hand to make sure the water hasn't found it's way into the engine.
Charlie Stephens
