06-01-2020, 03:18 PM | #1 |
8ba in a 32 ford
hey guys, im trying to put a 8ba flathead in my 1932 ford with a 39 3 spd trans. it has the original k member and a model a lowered front crossmember .i am using typical round rubber motor mounts, but the od of them are to large and hit the sides of the frame when i try to put the motor where it should sit..any pics or info would be great thanks!
06-01-2020, 03:27 PM | #2 |
Re: 8ba in a 32 ford
On all the 32 chassis I have built for myself and customers I put the weld on side mount brackets even with the top of the frame rails which leaves the top biscuit just a tiny bit on top of the rail.
06-01-2020, 06:37 PM | #3 |
06-01-2020, 07:25 PM | #4 |
I put an 8BA in my '32 p'up and used '32 mounts....worked real nice.
Charlie ny |
06-01-2020, 09:18 PM | #5 |
Charlie, That's how I'd do it if I had an original frame. Drake makes some nice original forged mounts. My reference above to how I mount my motors is in reproduction frames.
06-01-2020, 11:33 PM | #6 |
06-02-2020, 06:39 AM | #7 |
Rather than remove and reweld the mounts, make up a shim of the appropriate thickness to put you above the frame and place them underneath your biscuits......
06-02-2020, 03:47 PM | #8 |
I like to use 1951 mercury water pumps and the risers. I have to ask how are your hoses lining up would be my biggest concern.
Wanted flathead speed equipment Thanks |
