02-07-2011, 01:03 AM | #1 |
shorting a 32 raditor
i have an orignal 32 rad with a new core but i need to make it a 1inch shorter is there a easy way of doing it? with out getting a new core. thanks billy
02-07-2011, 01:16 AM | #2 |
Re: shorting a 32 raditor
there is no easy way to do that, even if you could find a rad shop willing to do it, first you have to get the tube plate off the tubes, then shorten every tube,then realign the tubes in the tube plate and resolder, the labor would be more than a new core
02-07-2011, 01:33 AM | #3 |
thanks thats what i was afraid of. i have 500 into it already.
02-07-2011, 06:10 AM | #4 |
I have one that would fit my A shell but was 4" too tall, I needed to do the same thing. My radiator guy had tried it once before & said it took a few try's to make it work, expensive. Since it wasn't a restoration he said cheaper/easier to make one from scratch using used tanks he keeps. Nearly $500 later I had the exact fit Radiators & tires the $$$ obstacles I find in putting together a car.
02-07-2011, 12:39 PM | #5 |
if you can get to a junk yard with your tape and the measurements you need you might be able to find one the right size or workable and then have your shop put the tubes where they need to be to fit your motor properly. i think my shop used a subaru or such. having one built = at least $400-500 in my experience.
02-07-2011, 01:27 PM | #6 |
Thread Tools | |
Display Modes | |
