10-04-2018, 02:50 PM | #1 |
distributor out of head
distributor is stuck in the head what the best ways of getting it out will not move
10-04-2018, 02:56 PM | #2 |
Re: distributor out of head
Make sure the retaining screw is removed.
Spray the base with penetrating oil. Apply heat to the base. I've been able to remove them by lightly tapping around the base [ and haven't broken one, yet] There is a tool made for its removal sold by the A vendors. I've never used the tool, but, many have. |
10-04-2018, 02:56 PM | #3 |
Apply penetrating oil (Kroil) to the base of the distributor body. NOT WD40. Give it time to work. A couple of days. It is very easy to break the dist. body. Be very careful prying on it. When doing do, pry evenly on both sides simultaneously.
I noticed the harder I work the luckier I get! |
10-04-2018, 03:10 PM | #4 |
Do not try to twist CW. CCW. There is a dowel pin under the base and into the head.
10-04-2018, 04:22 PM | #5 |
trying to help a guy out over text massages t told him to soak it has done it for couple weeks I will let him know to put a little heat on it
10-04-2018, 05:11 PM | #6 |
Bob |
10-04-2018, 05:56 PM | #7 |
he pull the head motor was stuck from sitting to long sent me pics don't look bad he is going to tare it down
10-05-2018, 11:33 AM | #8 |
it is a shame that some people don't take care of there cars
10-05-2018, 12:00 PM | #9 |
A little off topic - my truck has a light green motor as shown above. Was that an official Ford color? With the limited #s of As I have seen, the motors are a much darker green.
10-05-2018, 01:05 PM | #10 |
The engine was rebuilt put in a car and left sit out side for years what a shame going have to tare it apart will not turn over Sat with no hood on it don't know about the green
10-05-2018, 01:06 PM | #11 | |
David Serrano |
10-05-2018, 02:45 PM | #12 |
Here is a photo of an engine with the correct color green
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
