09-28-2015, 11:36 PM | #1 |
Anyone placed automatic in Model A?
Due to ongoing issues related to chronic back pain am looking for any experiences with installing automatic transmission. Dale OC Calif.
09-28-2015, 11:57 PM | #2 |
Re: Anyone placed automatic in Model A?
A search will find the information you need including make and model of tranny and vendors of the adapter kits. there are several threads with different info in each.
09-29-2015, 01:04 AM | #3 |
Yeah...I have a 9mm, a 40 and a 45 cal.
For starters
09-29-2015, 01:21 AM | #4 |
https://www.fordbarn.com/forum/showth...highlight=auto
Richie has also has a thread over on the HAMB which has some info. |
09-29-2015, 08:49 AM | #5 |
I had considered a C-4 at one time
V4f |
09-29-2015, 08:59 AM | #6 |
09-29-2015, 10:08 AM | #7 | |
How much frame modification did you have to do to shoehorn the A4LD into your rig? And what gear ratio did you use in the rear end?
09-29-2015, 10:12 AM | #8 | |
The 'hot' setup with the old timers was early Chrysler auto trans. Just missed getting one in a car with , already installed. Good luck with your chronic pain situation. I believe that that is the number one cause for the change that you seek , Last edited by hardtimes; 09-29-2015 at 10:13 AM. Reason: ....... |
09-29-2015, 12:01 PM | #9 |
Quite some time ago, The "Restorer" magazine had a good article on this subject. The person who needed the automatic had a disability that prevented using a clutch and gear shift. I wonder if there is an index where you could search for that article.
Good luck in your search. Rog |
09-29-2015, 12:21 PM | #10 |
Ask Jim Brierely, he knows a guy that shows up at hill climbs with
an auto trans in a model A and as I recall that guy makes a kit. |
09-29-2015, 03:13 PM | #11 | |
09-29-2015, 03:49 PM | #12 |
A Ford C4 is a very light weight, Aluminum automatic transmission.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
09-29-2015, 09:06 PM | #13 |
There is an ad on the Ford Pinto site for a C4 out of a 1972 Pinto with 26K miles, only $100. It is in Idaho. Here is a link to the ad:
http://www.fordpinto.com/index.php?P...a=view;id=3499 |
09-29-2015, 11:19 PM | #14 |
I am in Northern Calif. and have two C-4's if you need one.
09-29-2015, 11:47 PM | #15 |
If an automatic is needed, one might as well go modern and get an overdrive version, with lockup converter, also. A C4 was a good trans in its day, as was the A904 Torq-flite. But that was over 50 years ago! An A4LD would be a better choice. It's also a small trans, with O/D and lockup converter, light years ahead of a C4.
09-30-2015, 02:32 AM | #16 | |
I wonder what AOD would be a good fit? |
09-30-2015, 03:55 AM | #17 |
09-30-2015, 05:38 AM | #18 |
you have to get an earlier A4LD as the later ones are fully ecm controlled... are guys wiring a toggle switch for the converter lockup? or not usiing it ? and if so what are they doing on a 6v system? the early 904's had a mechanical converter lock up...
09-30-2015, 10:38 AM | #19 |
Why not look into a Shay replica.
09-30-2015, 11:01 AM | #20 |
nobody has the answers to my questions???
