Old 02-07-2019, 09:08 PM   #1
swoopNZ
MEMBER EMERITUS
Default 12 volts
A friend is going to install 12 volt headlamps in his 39 coupe.
He wants to know will he have to change everything else - eg:
generator to alternator, interior bulbs, radio, tail lamp bulbs etc.
Any Fords I have had in the past have always retained the 6 volt system.
Thanks in advance.
Chris.NZ.
swoopNZ is offline   Reply With Quote
Old 02-07-2019, 09:10 PM   #2
JSeery
JSeery's Avatar
Default Re: 12 volts
This appears to be a second post with the same question. It would be much better to keep this in one thread (the original one).
Old 02-07-2019, 10:07 PM   #3
swoopNZ
MEMBER EMERITUS
You are right - for some reason it didn't show up the first time ???
Old 02-09-2019, 10:50 PM   #4
Red98
Seems to happen when you interrupt writing a post for dinner.
Red98 is offline   Reply With Quote
