Old 05-10-2012, 08:06 PM   #1
1930pu
1930pu's Avatar
Default Got my parts back from the powdercoater
I got My wheels back from the powdercoater today had them done gloss black for my pickup WOW do they look great. Had 6 wheels done 2 truck running boards 2 engine pans and the headlight bar all gloss black . They blasted them and powdercoated them all for 360.00 even had them all packed in cardboard for me. I put the new blackwall tires on tonight hopefully get them on this weekend!! Thanks for all the advice when I was thinking of getting them done.
1930pu is offline   Reply With Quote
Old 05-10-2012, 08:30 PM   #2
Charlie Stephens
Default Re: Got my parts back from the powdercoater
If you are that happy with their work you should show their name and phone number.
Charlie Stephens
Old 05-10-2012, 08:35 PM   #3
Jim Parker Toronto
Jim Parker Toronto's Avatar
Don't forget to mount the tires from the back side so no marks will show, and use the garbage bag trick!
Jim Parker Toronto is offline   Reply With Quote
Old 05-11-2012, 06:07 AM   #4
William Kelchner
William Kelchner's Avatar
garbage bag trick ?
William Kelchner is offline   Reply With Quote
Old 05-11-2012, 06:16 AM   #5
Cider Mill
Cider Mill's Avatar
OK, now I need to go research the "garbage bag trick"?
Cider Mill is offline   Reply With Quote
Old 05-11-2012, 06:38 AM   #6
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I mounted all of mine without garbage bags by using two tire spoons covered with cloth and had no chips on ten wheels. Just have to be careful. Powdercoat is much more durable than enamel.
Barry B./ Ma. is offline   Reply With Quote
Old 05-11-2012, 01:01 PM   #7
C26Pinelake
I just mounted my new tires on freshly powdercoated rims and had great luck useing silicone spray on the tire. I have also used the garbage bags and it worked great. Both were tricks I learned here on FORDBARN !!
C26Pinelake is offline   Reply With Quote
Old 05-11-2012, 02:58 PM   #8
1930pu
1930pu's Avatar
I got them done at GT Fabrication in Pittston, Pa. 570-883-0775 nice people, they have also done auto frames and big objects. Yes when I came home I put the tires on, matched the dot to the valve stem and mounted them from the back with the 2 tire irons all went on good. Hope to mount on the truck Saturday. It is going to look great the truck is Duchess Blue
Old 05-11-2012, 04:56 PM   #9
Lawrie
Lawrie's Avatar
I just dropped of 10 wheels at the powder coaters here in QLD Australia, will let you know the cost,he said about $90 per wheel to blast and paint.
Lawrie
Old 05-11-2012, 06:47 PM   #10
dr.j
yup, and as Jim suggested, the garbage bags work great.
Dave A Jamieson
Portland, ON
Canada
1928 Tudor
dr.j is offline   Reply With Quote
