Old 02-07-2021, 03:54 PM   #1
Rustynutz52
Default Grease fitting size for 1937 ford spindles
What is the correct size grease fitting for 1937 ford spindles.
Thanks Mike
Rustynutz52 is offline   Reply With Quote
Old 02-07-2021, 10:41 PM   #2
fordor41
fordor41's Avatar
Default Re: Grease fitting size for 1937 ford spindles
I would thing 1/4-28 thread size
fordor41 is offline   Reply With Quote
Old 02-08-2021, 06:56 AM   #3
Mart
Mart's Avatar
I can confirm 1/4 - 28 (UNF)
Old 02-08-2021, 08:25 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
according to the parts book it is 1/8 pipe thread
Old 02-08-2021, 08:42 AM   #5
bbrocksr
1/4-28 I just got some for my spindles.
Bill
bbrocksr is offline   Reply With Quote
Old 02-08-2021, 08:58 AM   #6
rich b
rich b's Avatar
Here's a picture of some round-back spindles I had where you can see they are 1/4-28.
Old 02-08-2021, 09:20 AM   #7
DavidG
DavidG's Avatar
Kurt is correct, they are pipe threads, not 1/4-28 keeping in mind that the fitting has seal against leakage. They are so close to one another that it is easy to mistake one for the other.
Old 02-08-2021, 09:41 AM   #8
35fordtn
35fordtn's Avatar
they are Ford #353043-S7 which is 1/4-28 1/2" tall according to the Green Book, but in the 1928-38 catalog it lists 1/8" npt for 37-38 and 1/4-28 for 34-36
As David Says, they are close as 1/8" NPT is 1/4-27 so you can actually managae to install the wrong one and it'll still somewhat work
Old 02-08-2021, 03:24 PM   #9
bbrocksr
I,m going to have to disagree with you 1/4-28 is .250 in diameter, 1/8 pipe is close to .400 in diameter. They are nowhere close.
1/8 pipe and 3/8-24 are the one that are close.
I just finished putting kingpins in a pair of 37 spindles and they are 1/4-28.
I have 3 more sets and they are 1/4-28.
Compare a 1/8 pipe fitting and a 1/4 bolt to see the difference.
Bill
Old 02-08-2021, 03:33 PM   #10
bbrocksr
1/8 pipe is not 1/4-27, it is about .400-27 which is .150 larger than 1/4".
Bill
Old 02-08-2021, 03:35 PM   #11
Mart
Mart's Avatar
I know my 32 spindles are 1/8 pipe but my 39s are 1/4-28. So at some point in between Ford made the change.
Old 02-08-2021, 04:26 PM   #12
35fordtn
35fordtn's Avatar
Bill
You are correct..Sorry... However in the Ford 28-38 catalog it does state 1/8" pipe for 1932-34 and 1937-38
Old 02-08-2021, 04:53 PM   #13
Brian
Brian's Avatar
35 Fords have 1/4 28 NF grease nipples, so change must have occurred then
Old 02-08-2021, 06:02 PM   #14
Jim in Wisconsin
As far a a grease fitting sealing because of a taper, the 1/4-28 fitting are tapered, even though the threaded hole is not. If you look close at a 14/-28 grease fitting you can see the slight taper. They are supposed to tighten at the last thread and seal, at least seal enough so that grease doesn't squirt out.
The 1/8 pipe ones are also tapered, just like a pipe fitting would be. As others have said 1/8 pipe is much bigger than 1/4 inch.
Jim in Wisconsin is offline   Reply With Quote
Old 02-08-2021, 07:20 PM   #15
DavidG
DavidG's Avatar
My bad, I guess I was thinking of the '32-'34 fittings which are 1/8" pipe threads.
Old 02-08-2021, 07:29 PM   #16
Rustynutz52
Oh lord, it sounds like I need to buy both!!! I should have pulled them out before I had the axle cleaned up and painted. As always thanks, this site is awesome!!
Old 02-09-2021, 10:04 AM   #17
Don Rogers
Don Rogers's Avatar
I looked thru all my individual chassis parts catalogues to clarify the issue. They didn't. The 1/8" pipe grease fitting is listed as 353027-S7 and then its called 353047-AS7 and eventually 353043-S7. But it is eventually listed as being used for 33-34, 37, 38-48.
The 353034-S7 1/4" x 28 grease fitting seems to have been used on some 34 spindles and on all 35-36 spindles.
God Bless Henry and his Merry Men!!!
Don Rogers is offline   Reply With Quote
Old 02-09-2021, 10:49 AM   #18
Kube
Kube's Avatar
I have found nothing but 1/8" NPT on each and every 39-40 spindle I have ever worked with.
Old 02-09-2021, 04:33 PM   #19
bbrocksr
Kube, I've got 2 sets in front of me and 1 set I just installed on the axle, all 37-41 round back spindles. All have 1/4-28 threads I just put the grease fittings in last night 1/4-28 stainless fittings.
Bill
Old 02-09-2021, 05:47 PM   #20
JSeery
JSeery's Avatar
1/8-27 NPTF specs, thread dia is listed as .390
