04-11-2014, 01:58 PM | #1 |
Brake rod too long, but correct leagth
Rod is correct leagth but with eye all the way on still too long. What could be the issue?
04-11-2014, 02:02 PM | #2 |
Re: Brake rod too long, but correct leagth
Front axle?
If so the axle may be bent. The front axle is wont to "curl" around the front spring perch, particularly the section from the perch outwards - but possibly between sides. Check also your wishbone isn't bent - or disconnected where it attaches to the bottom of the transmission bell housing. Joe K
Shudda kept the horse. Last edited by Joe K; 04-11-2014 at 03:06 PM. Reason: perch for spindle |
04-11-2014, 03:06 PM | #3 |
Improper main/center adjustment ? Improper actuating arm angle ?
04-11-2014, 05:47 PM | #4 |
I vote actuating arm set wrong
04-11-2014, 10:49 PM | #5 |
Count my vote as well. The arm should "lean" towards the front of the car 15 degrees
04-12-2014, 07:05 AM | #6 |
Mark in MT Always looking for another opportunity to be wrong. |
04-12-2014, 07:12 AM | #7 |
Is the other rod on that axle too short? Possibly the cross shaft is not perpendicular with the centerline of the car (broken bracket, bushings are bad, etc?).
Are both rods on the axle too long? Possibly the bell crank isn't vertical when the brakes are off. How are the lengths of the rods to the other axle?
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
04-12-2014, 07:54 AM | #8 |
I've seen a lot of too short brake rods. I don't recall any being too long.
04-12-2014, 08:17 AM | #9 |
Make that 3 that vote actuating lever set wrong. Rod
04-12-2014, 08:56 AM | #10 |
How long are the rods eyehole to eyehole? In the service bulletins they give a dimension for solid non adjustable brake rods. You should be close to that length. Have you adjusted your brakes per the instructions in the service bulletins?
04-12-2014, 01:43 PM | #11 |
The eye to eye length is adjustable as needed. Bratton says their brake rods are 50 & 1/2 inches long this is without the adjustable clevis end. The front brake levers should lean foward 15 degrees with the slack pulled back as has been said. Most that I see the whole brake rod system is set up wrong. Forget about an exact length from eye to eye because Thats not the way its done if you want good brakes.
Here goes again on the brake rod setup. Disconnect all of the brake rods at the clevis end. Bring the plunger on the pedal rod 1/16th inch from the inside back of the center cross member , where it meets the plunger on the brake light switch. Adjust the clevis so that the brake pedal is at the top of its travel. With the front brake levers setup leaning 15 degrees foward as recommended, adjust the service brake rods so that the clevis pins will just enter with ALL slack free movement removed. Some in an attempt to do a good job go too far in shimming the front brake pin and end up with too much forward lean at the front brake levers and the threads on the front brake rod won't reach all the way through the clevis. When this happens, if its not too bad the pedal rod can be adjusted all the way back to the center crossmember. Ford recommended a 1/16 gap to prevent squeaks. I've never noticed squeaks when the pedal rod is adjusted in this manner and it allows the brake rod threads to pass all the way through the clevis ends.. Last edited by Purdy Swoft; 04-12-2014 at 01:54 PM. |
