06-09-2015, 03:24 PM | #1 |
Tin Can Sleeves
I read all the info in the recent V8 Times about the sleeves used in the early 24 stud engines. I've got one of these engines out of a '40 pickup and haven't used it due to the sleeves. If the sleeves are only 0.040 thick, could you just bore the cylinders out 0.080 or maybe 0.125 and run with no sleeves. Or, could you run with standard sleeves which are thicker?
Larry Young |
06-09-2015, 03:28 PM | #2 |
Re: Tin Can Sleeves
Is this where the .083 over pistons came into play? Press out the sleeve and hone.
06-09-2015, 03:52 PM | #3 |
Re: Tin Can Sleeves
Very common to remove the sleeves.
06-09-2015, 04:56 PM | #4 |
Re: Tin Can Sleeves
06-09-2015, 05:00 PM | #5 |
Re: Tin Can Sleeves
We usually bore to 3 3/16 and use standard 239 pistons, never had a problem.
06-09-2015, 05:52 PM | #6 |
Re: Tin Can Sleeves
06-09-2015, 06:33 PM | #7 |
Re: Tin Can Sleeves
I just got an 8BA with .083 pistons in it. They are .083 over 3-3/16". Best I can figure is that they are 8N/9N pistons. Must been what they had at the time.
Neal |
06-09-2015, 08:28 PM | #8 |
Re: Tin Can Sleeves
Curious is there issues going to .060? If not damaged. Just asking for me.
06-09-2015, 09:15 PM | #9 | |
Re: Tin Can Sleeves
Or are you referring to .080 + .060 for a total increase of .140? |
06-09-2015, 09:24 PM | #10 |
Re: Tin Can Sleeves
Ah ya. My bad on .040 sleaves. Just seems that going for max bore is norm. .08 being one more possible rebuild
06-09-2015, 09:36 PM | #11 |
Re: Tin Can Sleeves
06-09-2015, 09:47 PM | #12 |
Re: Tin Can Sleeves
Ya I guess. I get max bore. I guess I'm conservative and went from a .040 over to a .060. No sleeving needed for 2 more rebuilds. 37 block.
06-09-2015, 09:57 PM | #13 |
Re: Tin Can Sleeves
You must be putting the miles on them! I'm a go for the max type of guy myself LOL.
06-09-2015, 10:22 PM | #14 |
Re: Tin Can Sleeves
I understand. Hey I'm 40+ and hope to see at least one rebuild on the motor.
06-10-2015, 02:00 AM | #15 |
Re: Tin Can Sleeves
Don't get mixed up between the .040" wall thickness of the sleeve and going to +.060. The bore is over by twice the wall thickness of the sleeve, ie it is already +.080", so +.060 isn't the next size up, it's already bigger than that.
Mart. |
06-10-2015, 06:54 AM | #16 |
Re: Tin Can Sleeves
You cain't get the .0825 pistons anymore. I tried to get a set for an 8N tractor engine I built last fall. located 2 pistons. Wound up installing .100 over 8BA pistons. But 40-42 Ford, like O Ron, I've built many many going out to 3-3/16 8BA std pistons. Use the 40 A heads and you can feel the new torque in the seat of the pants. Walt
06-10-2015, 09:34 AM | #17 |
Re: Tin Can Sleeves
Good discussion.
Interesting.....the 8ba from Mater was bored to fit .083 Pistons. Presume this was done 25+ years ago in SoCal. Odd thing about the pistons they were .100 size turned to .083. Maybe a set done for the aforementioned engine and used on this project.
Tim Downtown, Ca |
