Old 01-24-2020, 09:22 PM   #21
Ziggster
Default Re: Allen Syncrograph Model E-316 Looking Info & Parts
Second one.
I want to give a big thanks to a fellow member who was kind enough to email a page from his manual. That's what makes this community so great. If anyone has any questions, please feel free to contact me.
Ziggster is offline   Reply With Quote
Old 01-27-2020, 04:29 PM   #22
Ziggster
Did some more digging and I think I figured out the positive and negative wires. It seems whoever worked on it even left a piece of black tape on the negative lead. The wire is still the original even though they added a cheap terminal connector, but the condition is such that it needs to be replaced.
Old 01-27-2020, 04:34 PM   #23
Ziggster
A few pics of the inside bottom rear corners. There is quite a bit of white powder, which is likely the result of severe battery corrosion. The rear opening seems to be the access for the battery, but I'm missing that cover. In pics of the same/ similar unit the cover has a few louvres it in. The bottom of the unit also has many small round holes which I'm guessing were to help vent the battery compartment.
Old 01-27-2020, 04:36 PM   #24
Ziggster
Other side. Damn I wish I could post multiple pics, but it never seems to work. Other corner.
Old 01-27-2020, 04:43 PM   #25
Ziggster
Another sort of anomaly is the blank hole near the tower for the distributor clamping mechanism. I've seen pics of some units with the same hole, others with something sticking out of the hole, but the pics are not that clear. Going through the drawer full of items, it seems like this knurled part is supposed to go into that hole. I have no idea what its purpose is, but it appears it was supposed to be connected to a chain.
Also, the manual mentions a worklight. There is an item on the schematic "Inspection Light", but I'm not sure if this is supposed to be the work light.
Old 01-27-2020, 05:08 PM   #26
Ziggster
D'oh. I think I figured out the "Inspection Light". It was under my nose the entire time, but the schematic mentions a two-prong connector, but it actually uses a three-prong connector. However, a quick check behind the connector mounted on the panel shows that only two prongs are actually used.
Old 01-27-2020, 05:11 PM   #27
Ziggster
Here is a pic from the manual. It is hard to see as the quality isn't that great, but it appears it is connected to the alligator clip used on the distributor lead. It definitely is not connected as mine is from near the Dwell/ Cam Angle Meter. It is located just above the distributor body.
Old 01-27-2020, 05:13 PM   #28
Ziggster
Additionally, I figured out what that knurled piece is for. It is the chuck key for the distributor rotating jaws, and is supposed to connected by a chain per the sales Brouchure.
Old 01-27-2020, 05:16 PM   #29
Ziggster
Exploded view of a pic from same sales brochure showing the chuck key.
[Edit] I just noticed there is no hole for the knurled chuck key in the pic from the manual in post #27. I'm guessing the unit went through several iterations during its life.
Old 01-27-2020, 05:35 PM   #30
Zeke3
Zeke3's Avatar
Ziggster, I have not seen one of these and probably never will, but have enjoyed the information. Thanks for taking us along as you become more familiar with this machine.
Zeke3 is offline   Reply With Quote
Old 01-27-2020, 05:36 PM   #31
Ziggster
This might be a candidate for repainting this puppy.
Old 01-27-2020, 05:38 PM   #32
Ziggster
Thanks. Hoping others can use the info. I enjoy this, maybe too much, as I should be working on my speedster. Lol...
Old 01-28-2020, 05:54 AM   #33
Ziggster
After taking a closer look at the VHT wrinkle paint, I realized that wasn't the correct finish. The correct paint finish typical for a lot of residential and industrial machines of that era was called hammer-tone, or hammered. It seems that there are not many options other than perhaps Rust-Oleum Verde Green (spray can) and Hammerite Mid Green (brush on). Krylon also sells a hammered paint line (spray can), but unfortunately nothing is available in green.
