Old 04-03-2012, 10:10 PM   #1
1931 flamingo
1931 flamingo's Avatar
Default Gauges
Getting ready to spend some Christmas present money. For late 31 which is more appropiate for add on gauges : APCO, Rex-A-Co???
Thanks in advance.
Paul in CT
Old 04-03-2012, 10:16 PM   #2
ctlikon0712
ctlikon0712's Avatar
Default Re: Gauges
Iv'e got the Rex-A-Co Oil press gauge and am happy with its looks and performance.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 04-03-2012, 10:27 PM   #3
TinCup
TinCup's Avatar
Default Re: Gauges
We have not had much success with the Rex A Co water temp gauges. We used a precision candy thermometer and brought hot oil to temp 260 degrees. We then tested 4 different Rex gauges and got 4 different readings. Also had 2 in the club where the needle fell off the gauge. These were all bought from different resources. We tested 3 older Stewart Warner temp gauges and they were all within acceptable tolerances. Haven't tried the APCO yet. With temps in Oklahoma these days and as much as we drive our cars temp gauges are a nice piece of mind.
Sooner Model A Club of Oklahoma
TinCup is offline   Reply With Quote
Old 04-03-2012, 11:41 PM   #4
Craig Lewis
Craig Lewis's Avatar
Default Re: Gauges
I like the vintage units which turn up at swap meets & ebay occassionally.
These are Rochester gauges.
I also have a Rochester room temp gauge which affixes to your headliner with 2 pins. It has a matching nickel bezel.
Craig Lewis is offline   Reply With Quote
Old 04-04-2012, 07:29 AM   #5
1931 flamingo
Default Re: Gauges
Craig: I've been watching and looking and haven't found a/thing or if I did didn't want it.
Now it's time to do something.
Paul in CT
Old 04-04-2012, 08:43 AM   #6
Bob-A
Bob-A's Avatar
Smile Re: Gauges
I've found that original Moto-Meter's if found in good shape. Give a better
(more correct) water temperature reading then the repop ones. Unfortunately the cost of them when found have been going way up of late! Plus, people are trying to sale repop's as originals I have discovered too.
Bob-A
Bob-A is offline   Reply With Quote
Old 04-04-2012, 10:28 AM   #7
1931 flamingo
Default Re: Gauges
I've got a beautiful quail w/patina so moto-meter not an option. Thanks
Paul in CT
Old 04-04-2012, 10:42 AM   #8
Oakridgeacres
Default Re: Gauges
I installed a (REX-A-CO) gauge a couple weeks ago. Installed per instructions from an earlier post. Gauge seems to work just fine. About 7# pressure when you first start up on a slight rev, but as oil gets warmer it goes down to just above readable when cruising at about 45mph. Is this about what other's have encountered with oil pressure gauges? Thought this was an appropriate question to go along with original post.
Oakridgeacres is offline   Reply With Quote
Old 04-04-2012, 12:51 PM   #9
HoarseWhisperer
HoarseWhisperer's Avatar
Default Re: Gauges
That's about normal with the oil gauge, depending on what weight oil used. They can be calibrated if necessary.
Flamingo,
Moto-meters were made for under dash and steering column too; not just as a rad cap.
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 04-04-2012, 01:26 PM   #10
1931 flamingo
Default Re: Gauges
Hoaesewhisperer: I did not know that!!
Old 04-05-2012, 07:35 PM   #11
Paul from Maine
Paul from Maine's Avatar
Default Re: Gauges
That's how mine performs in the summer with SAE 30 non-detergent oil. Since I switched to Mobil 1, I get a pound or so more pressure when the engine is warm. May be someone who knows about these things can explain the difference.
Paul from Maine is offline   Reply With Quote
Thread Tools
Display Modes
