Old 03-29-2020, 02:16 PM   #1
Vanspeed
Vanspeed's Avatar
Default 21 stud temp gauge question
Does the temp gauge bulb just screw into the waterpump? No special fitting? It looks like there is a tapered shoulder in the hole but not sure.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 03-29-2020, 02:24 PM   #2
Brian
Brian's Avatar
Default Re: 21 stud temp gauge question
The temp gauge used in these 21 stud engines is the capillary type; has the glass tube with red liquid. Yes, it seats on that tapered shoulder you refer to. The thread is 5/8 UNF. The later 24 stud engines use the electric type temp gauges. These screw into the heads with a 3/8 pipe thread. Will not fit the earlier engines
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 03-29-2020, 02:39 PM   #3
petehoovie
petehoovie's Avatar
Used one like this gauge on my '34 21 stud. No special fitting required...
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 03-29-2020, 05:20 PM   #4
Vanspeed
Vanspeed's Avatar
Ok thanks guys. I am running an aftermarket mechanical gauge and it looks correct I just was not sure if the waterpump needed a special fitting.
Old 03-30-2020, 03:25 PM   #5
31Abone
31Abone's Avatar
mine is in top radiator jose..sc
31Abone is offline   Reply With Quote
Thread Tools
Display Modes
