Old 09-05-2018, 10:11 AM   #1
VinceBlack
Default Model A U Joint repair
I would like to repair my A U Joint but am not sure how to get the old U Joint apart, I looked at the repair kit parts, any one know the best way to do this? Thanks for any help.
VinceBlack is offline   Reply With Quote
Old 09-05-2018, 10:46 AM   #2
Bob C
Default Re: Model A U Joint repair
See page 564 of the Service Bulletins.
Bob
Old 09-05-2018, 12:38 PM   #3
VinceBlack
Thanks Bob, where do I find service bulletins, are they available here?
Old 09-05-2018, 12:47 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
most u-joints are still good, most likely better than modern reproductions
if any of the bushings have been rotating in the 2 housings it most likely not rebuildable--the bushing has lost it's fit and is loose
the instructions say drive a cape chisel under the clip and pry it out ----cutting with cutoff wheel and pulling out the pieces works too---a little cut next to the clip helps get under the clip for removal if you have to save the clips
the side to side movement is part of the design and is needed
Old 09-05-2018, 12:55 PM   #5
VinceBlack
While setting at my bench staring at the u joint in the vice I did just as you said, using cut off wheel to cut clip. The cups were tight. Thanks for the advice. There are a lot of parts suppliers out there, any recommendations for quality parts?
Old 09-05-2018, 01:18 PM   #6
Bob C
Here are a couple of links to purchase the Service Bulletins, a must have book.
https://www.ebay.com/itm/1928-1931-F...sAAOSwk95bFA0r
https://www.brattons.com/paperback-m...bulletins.html
Bob
Old 09-07-2018, 12:53 PM   #7
1929 Red Tudor
1929 Red Tudor's Avatar
Heres a link to look at the service bulletins
https://www.modelagarage.com/service-bulletins/
1929 Red Tudor is offline   Reply With Quote
Old 09-16-2018, 06:07 PM   #8
RonFX
The replacement U Joint I installed needed the splines slightly touched with a dremel, everything was fine after that.
Thanks, Ron
RonFX is offline   Reply With Quote
Old 09-16-2018, 08:22 PM   #9
Lawrie
Lawrie's Avatar
Get onto barnfind 08 on the v8 forum,he has nos ford ones
Lawrie
Lawrie is offline   Reply With Quote
Thread Tools
Display Modes
