Old 04-18-2019, 02:01 PM   #1
DR
Default Starter issues
Good day,
Got the car started today 1930 ford however ...it stopped attempts to restart a than just heard a grind noise when I press on the starter any ideas what’s going on?
DR is offline   Reply With Quote
Old 04-18-2019, 02:38 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Starter issues
Was it turning the engine or just making noise?
Old 04-18-2019, 06:40 PM   #3
chap52
chap52's Avatar
Put the car in third gear and rock it back and forth. If you hear it pop loose it may be a bad spot on the ring gear. Just a thought??? Chap
Old 04-19-2019, 12:18 PM   #4
Will N
Will N's Avatar
Could be the bendix spring has broken, or the bolt holding it has broken. Not a hard job to remove the starter to inspect the situation.
Will N is offline   Reply With Quote
Old 04-20-2019, 08:35 AM   #5
DR
Well when I pushed the the starter i suspect it was turning the gear...don’t think the starter was doing anything
Old 04-20-2019, 08:37 AM   #6
DR
Got the starter out need to figure was it going on
Old 04-20-2019, 08:37 AM   #7
DR
Got it out need to trouble shoot
Old 04-21-2019, 05:47 PM   #8
DR
Thanks
