Old 10-24-2021, 08:33 AM   #1
Blastfromthepast
Default 1936 cabriolet ground strap location
Does anyone have a picture of the correct bolt on location
of the ground strap. Thanks.
Blastfromthepast is offline   Reply With Quote
Old 10-24-2021, 09:21 AM   #2
Don Rogers
Don Rogers's Avatar
Default Re: 1936 cabriolet ground strap location
The correct ground strap bolt on location is on the universal joint cover. See photos.
Don Rogers is offline   Reply With Quote
Old 10-24-2021, 09:24 AM   #3
Jacques1960
Jacques1960's Avatar
Piggybacking on this, can you also provide any information on battery hold down hardware for a 1936 Phaeton ?
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 10-24-2021, 09:41 AM   #4
Don Rogers
Don Rogers's Avatar
There is a detailed description of the hold down hardware in The V-8 Clubs 1935-36 Ford Book pgs 94-95
Old 10-24-2021, 10:53 AM   #5
DavidG
DavidG's Avatar
Don,
Except for the two upside down Vs with tails with threaded ends that secure the rectangular perimeter on top of the battery, the battery's position and how it is secured also shows up pretty well in your photo in #2 above.
Old 10-24-2021, 11:31 AM   #6
Don Rogers
Don Rogers's Avatar
Here's the photos from pages 94-95 in The 35-36 Book as well as a closeup from the photo above.
Old 10-24-2021, 12:08 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
I'd strongly recommend that anyone owning or working on a '35 - '36 Ford, pick up a copy of the V-8 Club's book that Don mentioned. It's a wealth of information, and can be ordered on the V-8 Club's website.
John
Old 10-24-2021, 07:10 PM   #8
Blastfromthepast
I have the book but it doesn’t have a detailed picture of the location for the bolt on
At least I didn’t see it but thank you Don for the pictures. As always thanks again for
All your help, Blast.
Old 10-24-2021, 07:24 PM   #9
Jacques1960
And thank you here as well; have the book and will look at images you refer to
Old 10-24-2021, 08:12 PM   #10
DavidG
DavidG's Avatar
scratched
Old 10-24-2021, 10:40 PM   #11
mercman from oz
mercman from oz's Avatar
Drawings of Ground Strap location, as supplied by Don Rogers.
Old 10-25-2021, 12:38 AM   #12
Don Rogers
Don Rogers's Avatar
I finally found the photo that shows where the ground strap is bolted to the universal joint cover caps. The driver's side bolt, lock washer, flat washer and nut assembly also holds the ground strap in place.
Old 10-25-2021, 01:12 AM   #13
petehoovie
petehoovie's Avatar
Old 10-25-2021, 05:19 PM   #14
Blastfromthepast
That’s perfect Don.
Thanks again for going the extra mile locating that picture. Thanks, Blast.
Also thank you Petehoovie for the blow up picture.
