10-30-2020, 03:41 PM | #1 |
Coil mounting position.
Several guys i know have made a bracket to turn the coil upside down and shorten the coil to distributor wire. Is there any science that shows that this is beneficial?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
10-30-2020, 04:00 PM | #2 |
Re: Coil mounting position.
I don't understand the question. Henry placed the coil with terminals facing down. To turn it up he other way, the coil to distributor wire has to be lengthened, not shortened and yes, I turn the coil terminals up. I was having too many coil failures till someone told me to turn the coil over. I have done that on all 4 of my Model As and haven't had a failure since. I don't care why that is, just that it is.
10-30-2020, 04:16 PM | #3 |
Syncro. Their mounting bracket lowers the coil.
10-31-2020, 07:42 AM | #4 | |
Depends on the coil. Tar or epoxy filled coils don't care how they are mounted. Oil filled coils do, they don't like to be tipped upside down. |
10-31-2020, 07:57 AM | #5 |
Sounds like it was mounted wrong in the first place.
10-31-2020, 08:37 AM | #6 |
10-31-2020, 08:49 AM | #7 |
I think ford mounted the coil terminal down to keep water out of the high tension terminal, he didn't use the rubber nipple on the coil wire, probably saved a penny or two!
10-31-2020, 09:25 AM | #8 |
This is an original Ford photo showing how the original coil was mounted.
10-31-2020, 01:34 PM | #9 |
I don't think it makes any difference in how long the coil to dist wire is, think about a 6' extension cord vs a 50' extension cord, both have 110 at the ends................
Paul in CT |
10-31-2020, 02:39 PM | #10 |
Yep, the length of the wire doesn't make much difference with the coil wire or condenser mounted at the coil. Electrons are pretty quick little buggers.
10-31-2020, 03:34 PM | #11 |
The new oil coils aren't filled full so the internal windings don't appear to get get coverage. Terminals up as suggested for those. Am also interested in the engineering explaining why some suggest the condensers can't be located up by the coil for less engine heat exposure.
Read somewhere that there is a relationship between point pitting, capacitance and wire lengths. Last edited by duke36; 10-31-2020 at 03:46 PM. |
10-31-2020, 04:10 PM | #12 |
The condenser can be mounted next to the coil and work for years if the condenser is a good one . I have used a modern condenser connected to the switch side of the coil for fourteen years on one of my model A's . If a person says that it won't work they simply don't know what they are talking about . I had one guy tell me on this forum a few years ago that it wouldn't work and he knew because he was an engineer . The guy said that the condenser must be close to the distributor , My reply was if the coil is mounted on the firewall in the usual location it will be plenty close enough to the distributor . Some of the older model A guys that I have known have knew this for over 60 years . The condenser must connect to the switch side of the coil . The condenser needs a good ground where it mounts or it probably won't work .
10-31-2020, 04:29 PM | #13 | |
There is a relation between capacitance and pitting. I forget which is which though, I knew at one time. I don't believe wire length has much to do with it though, within reason. |
10-31-2020, 04:41 PM | #14 |
he knew because he was an engineer . Well I am an engineer too. I run my trains around the Christmas tree every year. So there. I have several people tell me that they are an engineer or were related to one or knew one, bla bla bla. You would need to be an electrical engineer for this topic as even a structural engineer would not be qualified to intelligently argue this one. A structural engineer will not put his legal stamp on that kind of statement for which he could be held legally responsible.
10-31-2020, 05:03 PM | #15 |
My answer was from experience .
11-01-2020, 06:50 AM | #16 |
I used Google.
"If the tungsten transfers from the negative to the positive point one or two corrections may be made. Increase the capacity of the condenser, shorten the condenser lead, separate high and low tension leads between the coil and distributor, move these leads closer to the engine block. If the transfer is from the positive to negative point, reduce condenser capacity, move low and high leads closer together and/or away from the engine block, or lengthen condenser lead." http://www.austin7club.org/Ignition%20Condensors.htm |
11-01-2020, 10:21 AM | #17 | |
11-01-2020, 12:25 PM | #18 | |
The attached diagram is from the net also, and suggests a short piece of wire is needed with the condenser grounded to the firewall, etc. or attached to the coil bracket. Is that correct ? |
11-01-2020, 02:02 PM | #19 | |
Actually most condensers have the mounting bracket connected to its body, no extra wire usually needed. So about any quality condenser with the mounting tab and point attachment wire/pigtail can be mounted to the coil. With the poor quality of points and condensers today I think its a good to pay and hope you get one ones. I keep a known good one attached to the coil bracket but left disconnected until needed. Auto condensers/capacitors have a microfarad range from .2-.3 with most being in the .25-.28 range. So excessive pitting doesn't happen very often I recently went thru a bad condenser situation. 5 new 'burn-proof' condensers were junk. So the car now has 2 old known good ones in it. |
11-01-2020, 02:56 PM | #20 | |
Sent from my iPhone using Tapatalk |
