Old 09-24-2020, 01:02 PM   #1
STAN WHITE
Default 1933/1934 dashes
i would like to run a 33 DASH IN A 34 FORD. The reason is I want to use Stewart Warner Winged Gages. I have a perfect non molested Original 34 Dash. No Gages!. I do not want to modify a perfect 34 Dash, plus the work involved. Question is are the 33/34 Dashes the same as far as mounting and Column drop?. I think I might try to trade my 34 Dash for a like condition 33. I would not need the Gages or Engine turned panel. I have a 33 Bezel and will Engine turn a new panel for my gages. Thanks. Stan
STAN WHITE is offline   Reply With Quote
Old 09-24-2020, 01:06 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 1933/1934 dashes
It will interchange .Column drop the same.
Old 09-24-2020, 03:48 PM   #3
DavidG
DavidG's Avatar
Less known is the fact that early '34 dashes were actually carry-over '33s without a built-in instrument panel. A special panel equal in size to the surrounding raised area of a common '34 panel was used for the instruments and unless you look close you do not perceive that there are two separate components. Those special early '34 instrument panels are fairly rare. A NOS one sold recently on ebay.
Old 09-24-2020, 04:34 PM   #4
Karl
Karl's Avatar
Yep I have on in my car but of course mine RHD. As you say David you would never know looking at it that it was not all one piece -Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 09-24-2020, 05:17 PM   #5
mercman from oz
mercman from oz's Avatar
This is the Dash in my early 1934 Ford Phaeton. It is the one that David mentioned was fitted to very early 1934 Fords. As you can see, the panel that the instruments are mounted in is a separate piece, unlike the later 1934 Fords where this panel was molded in.
Old 09-24-2020, 05:23 PM   #6
mercman from oz
By comparison, this is the normal dash as fitted to 1934 Fords where the panel which houses the instruments is part of the Dash, not a pressed in panel like the very early 1934 Fords.
Old 09-24-2020, 10:20 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
What is that tiny tag located between the ash receiver and the cigar lighter in post #'s 5 & 6? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-25-2020, 03:26 AM   #8
mercman from oz
This is the badge on Australian 1933-1934 Fords. It reads "British Empire Products"
Old 09-25-2020, 04:29 AM   #9
tomkc1
tomkc1's Avatar
Fascinating stuff, guys. I learn so much from reading here. Thanks to all who share here.
Tom
tomkc1 is offline   Reply With Quote
