05-13-2018, 09:04 AM | #1 |
1930 Coupe Splash Aprons
Need to remove Running boards and splash aprons. Does the body need to be removed? Had to see as one eye has detached retina and needs heads up
Thanks Bob |
05-13-2018, 09:48 AM | #2 |
Re: 1930 Coupe Splash Aprons
No, you do not have to remove the body. but you need to unbolt the body and lift each side enough so you can remove the carriage bolts out and slide splash aprons out,
05-13-2018, 04:18 PM | #3 |
My '29 Coupe provided a good learning experience. Good luck.. kb |
