04-28-2021, 03:04 AM | #1 |
57 PS valve removal
Anyone know how to remove the PS valve from the pitman arm? Mine is stuck on there super super tight. This is on a station wagon.
Thanks, Mike
04-29-2021, 03:10 AM | #2 |
Re: 57 PS valve removal
The easiest method is with a tie rod puller. You can usually rent one from a box store.
DO NOT HEAT AND BEAT!
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 04-29-2021 at 03:16 AM. |
04-29-2021, 03:48 PM | #3 |
Thanks, I won't do the second anymore.
Mike
04-29-2021, 05:46 PM | #4 |
!!! JUST SAY NO TO THE HOT WRENCH and BFH !!!
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 04-30-2021 at 01:32 PM. |
04-29-2021, 07:20 PM | #5 |
In the 56 shop manual, a photo and caption reveal: Loosen the Nut back it off a bit, place a hammer behind the pitman arm and strike the stud-with Nut on it, with another hammer.
04-30-2021, 02:36 AM | #6 |
Mike
04-30-2021, 04:16 AM | #7 | |
When backing off the retaining nut, bring it down so as to be flush with the actual stud end to prevent mushrooming the stud end. Also say no to pickle forks. Can cause a lot of damage. Think safety glasses.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 04-30-2021 at 01:45 PM. |
04-30-2021, 12:53 PM | #8 |
Ordered a kit with various pulling tools so hopefully this will work. Then off to the races at getting everything else off.
Mike
04-30-2021, 01:27 PM | #9 |
Most likely the kit is off-shore (CHI-COM for 55blacktie as am now an official rascally racist) but be sure you have safety glasses when using.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
05-01-2021, 07:50 AM | #10 |
Yeah, I am sure it is. But, on short notice until I can find a US made set it will have to do.
Mike
05-01-2021, 09:40 AM | #11 |
Nah, what I am saying is that the off-shore may not withstand all of the pulling force. These things can explode, even top grade.
No use to buy first grade for something seldomly used.
05-02-2021, 07:48 AM | #12 |
I am aware of the 'non-strength' of Chinese tools. I am just hoping that they hold long enough for at least this one application. Normally I search for US made tools but in this case I am temporarily stuck with the Chinese stuff. I will see what happens on tuesday when I pull the springs and the rest of the steering items.
Mike
05-12-2021, 01:18 AM | #13 |
Well, I got the PS parts out along with both spindles and upper arms. Will work the lowers over this weekend. I had to use one of the tools that out of the kit I bought and it pushed it right off. The PS valve and ram will get packed and shipped to get rebuilt, just to make sure there is nothing wrong with them that I could not fix-and the price is right to boot.
I do have two questions though. 1) How do I get the new springs in without and engine to weigh down the frame? I compressed one spring 13" to get it out, I assume the new springs will have to be compressed 14"+ so I can get the spindles bolted up. 2) How do I get the upper bushings out with the shaft still installed? Mike
05-12-2021, 08:17 AM | #14 |
The engine is out of the car?
Did you use a spring compressor to remove the springs or just drop the lower control arm with a floor jack? |
05-12-2021, 09:31 AM | #15 | |
I think I have seen an aftermarket tool set (off-shore) that will do the same thing. A professional set is available from OTC TOOLS. Maybe a box store has one to rent?
05-13-2021, 03:26 PM | #16 |
Kultulz,
There is no engine in the car at this point. I used a compressor to compress them and then dropped the lower arm to get them out. I am just thinking ahead to when I have to jack up the lower arms to connect everything. The upper arms are out now, I just have to get the lowers out. The above kits have 'cups' that go around the shaft to push the bushings out? I think that is what is throwing me for a loop. Mike
05-13-2021, 06:18 PM | #17 | |
If out, why not take to a machine shop? FORGOT - Will your spring compressor compress the spring enough to sit it in there? If not, you will have to chain the frame down to the floor somehow if the frame raises while raising the lower control arm.
05-13-2021, 08:03 PM | #18 |
I may have to take them into a shop for pressing. I was hoping to save $30 a bushing in and out times 4.
Mike
05-14-2021, 04:20 AM | #19 |
I didn't realize things have gotten so expensive. SEARCH - CONTROL ARM BUSHING INSTALLER KITS and you might decide it is cheaper to buy a set. At least you would have them for future use. ALSO - https://www.amazon.com/OTC-7045B-Fro.../dp/B000GTJ5I8
05-14-2021, 05:15 AM | #20 |
I used a ball joint press kit from Oriely's to r&r the suspension bushings on my 61.
Dan Kingman Az. 86409 |
