07-12-2017, 06:23 AM | #1 |
Use of dual zenith carbs back in the 20's
Were dual carbs sometimes used back in their day on model A's or was this a very rare thing?
07-12-2017, 07:42 AM | #2 |
Re: Use of dual zenith carbs back in the 20's
If you look at the book called "Those wonderful unauthorized Accessories" you will see a number of dual carb set ups for sale in the Model A in the Model A era.
07-12-2017, 09:03 AM | #3 |
Your picture is two B Carbs, but yes as Lindy says, there were quite a few dual carb setups for the Model A. Lindy runs a dual carb setup on one of his Model A's.
07-12-2017, 02:03 PM | #4 |
Purdy (who used to post here) ran them. Do a search for his posts, he had pictures.
Paul in CT |
07-12-2017, 02:32 PM | #5 |
ran this setup on my 30pu
07-12-2017, 05:56 PM | #6 |
07-12-2017, 06:26 PM | #7 |
takes a bit to get them in sync.
No problem with driveability. Choke on 1 carb is enough for cranking. Makes about 6 more hp on dyno than a B carb and intake. Adds about 8-9 more ft lbs of torque at higher rpm. |
07-12-2017, 09:01 PM | #8 |
I've got the same setup as the picture in post #1.
It took a bit of trial and error to get the throttle plates in sync, but once adjusted it works very well and idles fine. It takes a bit longer to warm up than a single carb. The GAV on the rear carb is closed, only the front one can be adjusted. Both choke plates are linked. |
07-13-2017, 09:17 AM | #9 |
DOUBLE the carbs---DOUBLE the problems---NLOL!
Bill W.
