09-22-2021, 07:27 PM | #1 |
Old School Parking brake fixture for stretched cable
I tried searching for this but Mr. Google doesn't seem to remember the JC Whitney/ Western Auto gadget that clamped onto a stretched cable to 'shorten' it. Probably got outlawed. Seen them on the old wrecks I drag home. Do they still make them?
09-22-2021, 08:23 PM | #2 |
Re: Old School Parking brake fixture for stretched cable
GB, I may have one in my stash. I'll check and let you know. If I do its ours for postage.
09-22-2021, 08:33 PM | #3 |
It's actually for my '92 F350. I have had the rear axle mostly apart with new brakes, seals etc after a roadside disaster with perhaps too many beams on the load. Everything works well now, but no matter what, the parking brake doesn't grab until that far left pedal is about a 1/2" off the floorboards. Thanks! A simple device, just puts a kink in the cable to use up length.....
09-22-2021, 09:41 PM | #4 |
Gary: Rockauto see pic, I think the hook/bolt is in backwards in the picture, I may order one to have on hand.
https://www.rockauto.com/en/parts/do...adjuster,10479 Also carried by advance auto and Oreilly and eBay. https://www.oreillyauto.com/detail/c...ter/mtm0/03006 Last edited by corvette8n; 09-22-2021 at 10:38 PM. Reason: Added link |
09-22-2021, 10:14 PM | #5 |
If necessary, 'gang' them. I think my old truck has at least two of them.
09-22-2021, 10:33 PM | #6 |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) Last edited by GB SISSON; 09-22-2021 at 10:42 PM. |
09-27-2021, 02:33 AM | #7 |
Can you link to the Dorman items?
09-27-2021, 03:35 AM | #8 |
Dorman #03006, available at O'Reiley's, etc! DD https://www.oreillyauto.com/detail/c...ter/mtm0/03006 |
09-27-2021, 10:32 AM | #9 | |
09-27-2021, 11:29 AM | #10 |
Yep, the two nuts are used to adjust and tight the J-hook and go either side of solid part at the end where the hook is now. The J-hook needs to be between the studs to pull on the cable.
09-27-2021, 07:16 PM | #11 | |
Interesting, I've always just seen them double nutted on the outside. I can see your point though. |
09-28-2021, 04:47 AM | #12 |
I bought a couple last year from Napa and asked this thing is backward he said yes that's for packaging.
