11-20-2012, 11:31 AM | #1 |
Penetrating Oils
I thought that you’ all would find this interesting!
Penetrating Oils Machinist's Workshop Mag recently published some information on various penetrating oils. The magazine reports they tested penetrates for break out torque on rusted nuts. They arranged a subjective test of all the popular penetrates with the control being the torque required to remove the nut from a "scientifically rusted" environment. *Penetrating oils ........... Average torque load to loosen* No Oil used ................... 516 pounds WD-40 ..................... ... 238 pounds PB Blaster .................... 214 pounds Liquid Wrench ...............127 pounds Kano Kroil .................... 106 pounds ATF*-Acetone mix............53 pounds The ATF-Acetone mix is a " mix-your-own-brew" -- 50 - 50 automatic transmission fluid and acetone. As noted many times in FordBarn threads! Note this "home brew" released bolts better than any commercial product in this one particular test. A local machinist group mixed up a batch and they all now use it with equally good results. Note also that "Liquid Wrench" is almost as good as "Kroil" for about 20% of the price. Steve from Godwin-Singer says that ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix. *ATF=Automatic Transmission Fluid Last edited by Steve Staysko; 11-20-2012 at 05:56 PM. |
11-20-2012, 12:50 PM | #2 |
Re: Penetrating Oils
Great information! I've filed it away for future reference.
Could you post the link to the report?
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
11-20-2012, 12:52 PM | #3 |
I just made a copy of this to show others of this information. We need all the help we can get with those rusty nuts.
11-20-2012, 02:08 PM | #4 |
Thank you for making the information available. Nothing better than having the facts!
-Conrad |
11-20-2012, 04:37 PM | #5 |
Machinist's Workshop Magazine
Testing Different Types of Penetrating Oils By: Lloyd Bender Subject: Cutting Issue: MW Vol. 20 No. 2 Apr-May 2007 Here is a copy from another source.... http://www.antiquemodeler.org/sam_ne...am_2011_07.pdf Last edited by Steve Staysko; 11-20-2012 at 04:51 PM. |
11-20-2012, 05:03 PM | #6 |
11-20-2012, 05:49 PM | #7 |
Where you guys been hiding? We been bragging about ATF & ACETONE for years!
11-20-2012, 06:57 PM | #8 |
Yep!, been using it for a coupla years now. Been here in the forum several times.. Anybody use the new stuff from WD40, they just came out with a similar product.
11-20-2012, 07:33 PM | #9 |
A fellow that owns a parts house told me the best penetrating fluid was brake fluid. I have never tried it tho. Charles
11-20-2012, 07:34 PM | #10 |
My nuts are rusty, but I ..... oops, wrong forum....
11-20-2012, 07:45 PM | #11 |
Howes penatrant is my fav !
Mac tools exclusive |
11-20-2012, 07:50 PM | #12 |
11-20-2012, 08:08 PM | #13 |
Bassman - A wire brush will usually take rust off. . . . . .
11-20-2012, 08:26 PM | #14 |
what about one of those things that splits nuts....lol....Mike
11-20-2012, 09:10 PM | #15 |
Have good luck with Kroil oil. Ford recommended, too!
Barry 50 F-1 |
11-20-2012, 09:26 PM | #16 |
I'm definitely switching to the home-brewed version penetrating oil
-Conrad |
11-21-2012, 08:35 AM | #17 |
Anybody ever scientifically tested the "candle wax melted into the studs" method? I have not done that yet but planning on it for the next tear down.
11-21-2012, 10:38 AM | #18 | |
R |
11-21-2012, 11:32 AM | #19 |
Just posted this on the Shoebox Ford forum. Heard about using the ATF mix before but nice to see the comparison. Thanks for the info. Bob
11-21-2012, 01:31 PM | #20 |
I had one batch of PB Blaster that was useless and now my next gallon of it is amazing..and way better then any I had used before. I have used ATF and acetone also and it does work very well. thks for posting the results, bob
