Old 01-08-2018, 01:42 AM   #1
oz40
oz40's Avatar
Default 1940 Ford Grill
Does anyone know something about this type of centre grill in the 1940 Ford??
oz40 is offline   Reply With Quote
Old 01-08-2018, 02:02 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: 1940 Ford Grill
Has lots of similarities to the 1941 Ford Grille?
Old 01-08-2018, 02:17 AM   #3
mercman from oz
Here is a 1941 Ford Grille for comparison. The vertical lines are similar, but that is where the similarity ends. Sorry, can't help.
Old 01-08-2018, 02:47 AM   #4
Graeme / New Zealand
Graeme / New Zealand's Avatar
I see this vehicle is some sort of rod ,perhaps it is clever custom made job. Well done if it is.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 01-08-2018, 11:07 AM   #5
deuce_roadster
deuce_roadster's Avatar
Looks like a 41 maybe modified to bolt into a 40. Or maybe it just does bolt in.
Old 01-08-2018, 11:29 AM   #6
'36 5W
'36 5W's Avatar
Or Aussie o.e.m. variation?
'36 5W is offline   Reply With Quote
Old 01-09-2018, 07:19 AM   #7
tub1
tub1's Avatar
I kinda know the guy who owns this 40 if he is at the event we are going to next weekend I will ask him he is a nice chap and has owned the 40 for ever
tub1 is offline   Reply With Quote
Old 01-11-2018, 01:22 AM   #8
Detonator
Detonator's Avatar
I have a set of '40 Standard repop grilles that came out of South America, I was told they were made back in the 70's. They're well-made, but not perfectly accurate. Maybe they offered a Deluxe version?
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 01-14-2018, 07:05 PM   #9
tub1
tub1's Avatar
talked the guy with the 40 yesterday , told me the grill was made in war time cast in brass stronger than dicast mud metal , maybe the bullets wouldn't damage it lol , also told me headlight frames are brass the car has been on the road as a hot rod 30 plus years
Old 01-14-2018, 08:21 PM   #10
Charlie ny
The horizontal fins on the side vents are complimented by the vertical bars......KOOL.....
to my eye anyway.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 01-15-2018, 01:15 AM   #11
Maybe those old die cast 40's shook apart on your corrugated bush roads. I understand that was an issue with the Pilot grills for those that lived "out back and beyond".
GB
Old 01-21-2018, 04:10 AM   #12
oz40
oz40's Avatar
Thanks for the comments so far,, I have been contacted by the owner (original car) of the '40,, as well as a revered early ford person,, Both have given different explanation on the possible grills origin,, down here in Australia. And it appears that the production of this grill was specific to the '40 for the aussie produced cars. Unfortunately none of the above suggestions come close... So I will leave it up here for a little longer and see what you guys come up with.
Old 01-21-2018, 06:13 AM   #13
47Merc
I don't believe that it is a Ford manufactured Grill. For a start it would have had a crank hole in the middle if it was.
I have been playing around with 39 - 40 Fords most of my life and owned quite a few and have never seen one like that before. When I first saw the photo I thought Ford Pilot.
I had a friend who was a die hard 40 man and for years he collected NOS Ford parts from all over outback Queensland and New South Wales as his job took through those areas and at one stage he had about 15 of the 1940 cast grill sections. The majority of those sections were for the left side as the right hand ones broke when the crank handle was pulled upward trying to start the car. He didn't have any that were different to the genuine Ford ones and I'm sure that if there had been any out there he would have found them.
Can you tell us what the part No. on it is?
47Merc is offline   Reply With Quote
Old 01-21-2018, 07:44 PM   #14
Possibly made from 4E93A Prefect grille??
GB
Old 01-24-2018, 03:19 AM   #15
oz40
oz40's Avatar
Thanks guys for the responses,, I was curious to hear if there was a qualifiable answer on these grills.
I did get some follow-up from the owner of the all original 40, and from another ford nut.
The following comments from the owner are,
"They were made of solid brass for staff cars in WW2 . Deflect bullets I was told."
And from the learned Ford man,
"Yep, used to be a white '40 sedan in the Bendigo area that had the same grille. Most likely it's a replacement grille made after the War when parts were scarce, they also made cast brass headlight rims around that time too...someone said they were done for the insurance companies of the time, but that might be a bit of folklore...who knows."
So still no clear answer,, but a curious piece of Ford history.
