Old 08-25-2019, 06:35 PM   #1
shew01
shew01's Avatar
Default 1931 Wheel Bearings and Brakes
Yesterday, I was planning to repack the wheel bearings, and I couldn’t remove the drum because (I think) the brake shoes where hanging on the drum. I was afraid to loosen the brakes (because I’m a first time A owner, and I didn’t want to open Pandora’s Box and have to readjust the brakes.)
The outside bearing came out okay, and I repacked it before giving up on the inside bearing.
Is it “normal” for the brake shoes to make drum removal difficult?
shew01 is offline   Reply With Quote
Old 08-25-2019, 07:03 PM   #2
Clem Clement
Clem Clement's Avatar
Default Re: 1931 Wheel Bearings and Brakes
yes. Back them off. The rim can get enough wear to hold the shoes hostage.
Clem Clement is offline   Reply With Quote
Old 08-25-2019, 07:16 PM   #3
Mulletwagon
Mulletwagon's Avatar
A couple of CCW clicks on the adjusting studs should retract the shoes enough for easy removal of the drum. Fear not - just jump in after a little homework !
Mulletwagon is offline   Reply With Quote
Old 08-25-2019, 07:50 PM   #4
shew01
shew01's Avatar
Thanks. I’ve read about Brake adjustment, and it sounds complicated. Can “mere mortals” do this without fowling it up?
Old 08-25-2019, 07:57 PM   #5
Curtis in MA
When you back off the adjuster count the clicks and write it down. When you put them back on tighten that many clicks.
Curtis in MA is offline   Reply With Quote
Old 08-25-2019, 07:59 PM   #6
shew01
shew01's Avatar
I just saw your post. If I count the clicks, can reverse the clicks the same amount and have roughly the same braking as before I “messed” with the brakes? Or, is it a “start from scratch” adjustment experience that I’m in for?
Old 08-25-2019, 08:00 PM   #7
shew01
shew01's Avatar
Thanks! That sounds like I stand a fair chance of not messing this up.
Old 08-25-2019, 08:32 PM   #8
Mulletwagon
Shew,
You will probably need to do a total brake adjustment. Would recommend the "board" method. Might find the following helpful. Good Luck
https://www.youtube.com/watch?v=wMizfaKHXVQ
Old 08-25-2019, 08:51 PM   #9
shew01
shew01's Avatar
Thanks for the video. The previous owner sent a board with the car.
Old 08-25-2019, 09:26 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
You have the "Andrews red book" right?
Old 08-25-2019, 09:41 PM   #11
CWPASADENA
CWPASADENA's Avatar
As stated before, just counts the clicks and you will be fine.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 08-26-2019, 04:24 AM   #12
shew01
shew01's Avatar
Yes, I do have the red book, and I recall reading about brake adjustment several weeks before I purchased the car (and it sounded complicated, at least to someone who has never adjusted Model A brakes before). However, I couldn’t find what I needed in the book when I had the wheel off the car, and I didn’t want to end up with a snowball of repairs that would keep me from driving the car for an extended amount of time. (Wow, I underestimated how folks tend to react to these old cars when you drive them. Kid especially seem to enjoy seeing them and hearing the horn. I took the car to church on Sunday, and we had a “meeting” in the parking lot after the meeting inside. It was hilarious.)
Thanks for the feedback. I plan to start by counting the clicks the next time I get an opportunity to work on the car. If reversing the number of clicks doesn’t leave me with good stopping power, I plan to do a deeper dive on brake adjustment.
