Old 07-22-2019, 03:38 PM   #1
46woodie
Default 46 wagon passenger tailight bracket?
On the factory tailight bracket drivers side, the license plate bracket has a small hole to attatch the forged piece (arm)coming up from the frame that the wiring is secured to. On the passenger side I do not want a license plate bracket, was there something from the factory offered with the optional tailight assembly that attached to this arm .Any pictures of passenger tailight assembly you could post for me? Probably just fabricate something but would like suggestions. Thank you!
46woodie is offline   Reply With Quote
Old 07-22-2019, 04:13 PM   #2
woodiewagon46
Default Re: 46 wagon passenger tailight bracket?
I used the drivers side bracketry and cut off and shaped everything to make it look like factory. I'll see about posting pictures.
woodiewagon46 is offline   Reply With Quote
Old 07-22-2019, 09:44 PM   #3
Mtn Wudy
Mtn Wudy's Avatar
Trying to send photo ......
File Type: jpeg 9415FEEF-63BE-4894-A65A-1E8E0195F31D.jpeg (61.2 KB, 20 views)
Whether you think that you can,or that you can't,you are usually right....H.Ford
Mtn Wudy is offline   Reply With Quote
Old 07-22-2019, 11:16 PM   #4
mrtexas
mrtexas's Avatar
I like two. I put a phony plate on the right side that says 2thpix
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 07-23-2019, 09:22 AM   #5
woodiewagon46
Mine is similar to Mtn Wudy except I rounded off the edges. I had two like Tex pictures, and had a plate with 1946 on it. I was stopped by the police one day and he was very nice about it, but suggested I remove the other plate because it's illegal to display two plates.
Old 07-23-2019, 12:58 PM   #6
46woodie
Thanks for everyones input!! Curious, was the extra tailight a Ford option from the factory or add-on later? What was offered originally for this bracket we're talking about? I've never seen the passenger tailight assembly up close so wasn't sure what they would even look like. Thanks again!!
