05-18-2019, 10:35 AM | #1 |
Coolant
Any thoughts on Evans waterless coolant? I was thinking of using it in my 53 Ranchwagon. Fresh rebuilt flathead, and nothing in the cooling system yet. I figured this would be a good time to use it. Seems like it would be perfect for a seldom driven vehicle.
05-18-2019, 11:49 AM | #2 |
Re: Coolant
05-18-2019, 01:39 PM | #3 |
Re: Coolant
All Evans does is lighten your wallet. A nice clean cooling system and regular 50-50 coolant and water will work just fine.
05-18-2019, 02:35 PM | #4 |
Re: Coolant
I guess I was thinking more on the rust prevention side. After further review I will go with antifreeze.
05-18-2019, 06:13 PM | #5 |
Re: Coolant
Save your money. Just use a 50/50 mixture of Prestone and change it every two year's to prevent electrolysis. A flathead is just an engine like any other engine, it does not need any kind of magic coolant.
05-27-2019, 10:01 AM | #6 |
Re: Coolant
05-27-2019, 08:59 PM | #7 |
Re: Coolant
any good quality premix coolant works fine [QUALITY]is the catchword
05-31-2019, 02:58 PM | #8 |
Re: Coolant
06-01-2019, 02:24 PM | #9 |
Re: Coolant
I use propylene glycol, sold under the brand name "Sierra". It works fine, and will not pollute or poison pets if any leaks.
06-01-2019, 09:10 PM | #10 |
Re: Coolant
yes premix costs more but the mix ratio is important if the coolant is to work correctly ie freeze point , boil point and corrosion resistance if your confident to mix your own that's a bonus, premix is peace of mind
06-02-2019, 12:21 AM | #11 |
Re: Coolant
Agree with you. Mix of 50/50 of concentrate with water. Been doing it for years in the Pacific Northwest............
06-02-2019, 07:00 AM | #12 |
Re: Coolant
I mix mine but it still should be tested for its freeze point. Im careful to mix it correctly and had a batch that wasn’t low enough. I think it was 50/50 in a “concentrate” container....Mark
