09-10-2017, 09:35 AM | #1 |
29 Tudor outside door handle question
The 29 Tudor that I am restoring has an outside door handle for the right side that the lock is either rusted and won't turn or I don't have the right key.
How can I tell if this handle is original or repo? Can a locksmith make a new key without taking it apart? And does anyone know how this unit comes apart? Please see pix below. |
09-10-2017, 12:22 PM | #2 |
Re: 29 Tudor outside door handle question
you have an original handle. the tumbler in it is partially turned so that tells me it might junk. the handle itself looks to be good. if only the tumbler is bad, I would clamp it up in a drill press and drill out the tumbler. once you drill it out too 3/8" down inside there is a little spring keeper remove it and the rest of the tumbler will come out. if someone has another tumbler with key you just push it right in with a little twist and you are up and running. that tumbler was used 28 to mid 30
09-10-2017, 01:31 PM | #3 |
The handle is original stainless so most likely off a 30/31 car . You have the key code on the shank looks like 1094 you can obtain a key . Soak the handle in solvent for a while and try the key . The Barners here will tell you where to get one or get two one for a spare !!! . Dont drill anything out until the last resort .
John in same grotty weather Suffolk County England . |
09-10-2017, 01:45 PM | #4 |
My handles are original(fordor). My car has been garaged its whole life(I think). And my handles look 85 years old. no rust but the chome looks terrible its all pimpley and dull and looks 85. Also not sure if its a Briggs thing or fordor thing. But there is a key cylinder below the handle not in it.
edit: i read the other responses and stainless wouldn't wear like my pot metal cast handles have. but pb blaster or wd or oil or anitseeze in the lock could free it. |
09-10-2017, 05:10 PM | #5 |
I think your handle are original 28/29, as the contact part to the door is just slightly curved, not curved as much as a 30/31. Your handle is nickel plated brass clad. I had Dick Crabtree restore a pair of mine. He is a magician with door handles including the keying. What ever you do, don't toss it. It can probably be restored to like new.
Rusty Nelson |
09-10-2017, 06:21 PM | #6 |
09-10-2017, 06:40 PM | #7 |
Keep WD-40 away from pot metal, like your handle lock. It can make it swell.
If you get the correct key cut from A&L or someone else, and it still doesn't work, then I'd send it to Dick Crabtree. |
09-10-2017, 08:43 PM | #8 | |
09-11-2017, 10:22 AM | #9 |
09-11-2017, 05:47 PM | #10 | |
Can the lock assembly be removed from the handle without a problem? |
09-11-2017, 08:52 PM | #11 | |
Seems that with the key code and the lock itself a locksmith can make up a key easy enough, but if you are having trouble getting it apart, then you could take the whole thing into a locksmith and they could get it open. One thing I don't know (lack of experience) is if the standard door lock fits a standard key available these days. My assumption would be yes, but I certainly don't know. I am interested in this because for my '29 Tudor, I have a door handle with a lock but no key. My ignition lock is a modern aftermarket switch, and not even one of the pop-out look alike deals. I was able to get new copies of the ignition key made at Home Depot because it takes a standard key blank. I would have to take my handle into HD to see if they have a blank that fits, and I just might do that some time soon. It is easy enough to take the handle off. On the other hand, if someone else knows if the door lock is a standard key blank, I would be interested to know. |
09-12-2017, 12:06 AM | #12 |
Fred93,
A Model A lock with a code between A1051 & A1300 would be for a 1928-29 Door or Tire lock. Your code of A1094 would use a "B1" key blank with a cut code of "33351". Any good lock smith should have "B1" blanks and be able to cut you a key. Don't let them charge you an arm and a leg. Grainger sells a bag of 25 "B1" blanks for around $7.00, thats .26 a key. All else fails, then as stated above send it to Dick Crabtree. Good luck, Ed |
09-12-2017, 06:12 AM | #13 |
A&L is an excellent Model A parts maker and seller, but I'm away from home and don't have their address or phone number. A search here should turn it up.
BTW, I have a mint locking 29 Tudor handle, but it's too bad it was plated with the lock in place. |
12-04-2019, 10:28 PM | #14 | |
