04-23-2017, 10:17 AM | #1 |
Banjo Steering wheel identification help needed Lincoln?
I have had this wheel on my 1932 ford and it has a f-100 steering box with splines and this wheel is or was on it . I have had her for years and have never seen one what is it? Thank you
Wanted Roadster Pick up thank you COLOR] |
05-05-2017, 10:52 AM | #2 |
Re: Banjo Steering wheel identification help needed Lincoln?
It is from a 38, 39 Lincoln Zepher.
05-05-2017, 11:42 AM | #3 |
That is not a '38 or '39 LZ steering wheel. I can't post photos but if you check out Ken Alabama's latest post on his '39 LZ Coupe, you'll see what the '39 LZ steering wheel looks like.
05-05-2017, 11:47 AM | #4 |
I wonder if the splines are from the wheel being forced on a shaft with splines. Is the hole tapered and the splines only in the small end? As posted on the HAMB, it sure looks like wheel I did not get off a 37 Lincoln.
05-05-2017, 03:47 PM | #5 |
This is the 38-39 Zephyr wheel . The center hub in your wheel is larger than the 38-39.
05-05-2017, 06:44 PM | #6 |
05-05-2017, 07:30 PM | #7 |
My lazy self looked up 37 Lincoln and it sure is not that. As someone previously suggested, it may be British. Hope someone knows.
05-06-2017, 08:55 AM | #8 |
Looks like it might be off an old Jaguar or MG TD.
06-23-2017, 08:18 AM | #9 |
Any ideas guys what this neat wheel came off of
12-26-2017, 09:38 AM | #10 |
Any ideas guys what the wheel is? It came off a 1934 Pheaton with a f-100 steering box
12-26-2017, 02:21 PM | #11 |
Splined type hubs generally don't have a big keyway as that one does. I don't know of an Ford product that would have used that wheel. It could have come from a boat for all I know.
12-26-2017, 02:54 PM | #12 |
Could it be home made ? Looking closer it seems to have been assembled ( spokes ) then epoxy overhead two of the 3 sets of stainless ? rods .
12-26-2017, 06:16 PM | #13 |
It's difinitely not homemade the way it's constructed and cast plastic looks to be untouched but is a bit dirty and uncleaned. Plus Alfin has one exactly on his 1932 roadster and he's wondering the same thing what's it from?
QUOTE=Ggmac;1570897]Could it be home made ? Looking closer it seems to have been assembled ( spokes ) then epoxy overhead two of the 3 sets of stainless ? rods .[/QUOTE]
12-26-2017, 06:19 PM | #14 |
I never though of a boat and they used many suppliers . I was hoping to find a name like Shillings on it but no luck. I have to check out my old speed catalogs for aftermarket steering wheels... Thanks for the reply
02-16-2018, 10:20 AM | #15 |
I found another picture of the wheel but this time in a Rodding and Re-styling from 1958. I am a book junkie and can't read enough and the other night a ran across this hot rod 1932 cabriolet . Thanks
