Old 12-01-2016, 09:53 AM   #1
Steve Plucker
Default Bent OD Electric Windshield Wiper base
How would one succefuly take the bend out of an OD Electric Windshield Wiper base?
The cover fits good except there is about an 1/8 of an inch bend at the top. This base is popmetal so I do not know how it would be done without breaking it.
Maybe I just sould live with it.
Repro bases suck.
Thanks.
Pluck
Old 12-01-2016, 10:02 AM   #2
wrndln
Default Re: Bent OD Electric Windshield Wiper base
Steve,
OD electric wipers have a base made of pot metal. As you probably know, pot metal doesn't hold up well at all over time. I think trying to straighten the base would probably break it. New aluminum bases are available from Model A Wipers and model A parts suppliers. I had John Holland restore an OD-C1 for my 28 special coupe and an OD-O1 for my 29 phaeton. Both needed new bases, as the pot metal was bowed and badly cracked. I think if I were you, I would leave it alone for fear of breaking it or if you just can't live with the bow, replace it with a new aluminum base.
Rusty Nelson
Old 12-01-2016, 10:17 AM   #3
d.j. moordigian
d.j. moordigian's Avatar
Steve,
I agree with Rusty. Just maybe, Tom could work a miracle with the JB weld,...call him.
d.j. moordigian is offline   Reply With Quote
Old 12-01-2016, 11:57 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
If I'm the Tom, I can't work that kind of miracle.
I agree with Rusty to buy an aluminum base.
Old 12-02-2016, 09:39 AM   #5
wrndln
Dudley is referring to Tom Moniz. He took a badly broken pot metal cover for an OD-C3 electric wiper and restored it to perfect condition, mostly using J-B Weld. It was in a recent issue of Model A News or The Restorer magazine. He did an amazing job of putting the many pieces of the cover back together. I wouldn't attempt to do what he pulled off. I took a couple pictures of the article about Tom's excellent wiper cover restoration.
Rusty Nelson
File Type: jpg Tom Moniz's broken OD-C3 cover repaired.jpg (50.2 KB, 54 views)
Old 12-02-2016, 10:36 AM   #6
Steven Ryan
I made them work fine after placing the legs on a belt sander. When you install the rubber end caps, all looks perfect.
Steven Ryan is offline   Reply With Quote
Old 12-02-2016, 10:52 AM   #7
d.j. moordigian
Sorry Tom,....didn't mean to leave you out of the loop...
When you go to your Model A meeting with Rusty,...get the book from
the library,..good article..
Old 12-11-2016, 06:10 PM   #8
david801
david801's Avatar
I have a OD-C1 with one of the mounting ears broken off. I purchased one of the reproduction bases from Bratton's. It was expensive. around $120. I was impressed how well it was made. The only thing I had to do it was use a Dremel to grind down around the outer edge a little so the cover fit better. I heard that the guy who was making these bases and other parts for the Owen Dyneto wipers has gone out of business.
david801 is offline   Reply With Quote
Old 12-12-2016, 10:07 AM   #9
100IH
Steve, I have had good luck straightening pot metal carbs on Farmall Cubs, not quite so old but subjected to much more heat than a wiper casting on an A. Worked cold using controlled force against an iron plate for support with shims, Nothing to loose if it's unusable now. Do a search on farmallcub.com. Mark Jacobson in Kuna.
100IH is offline   Reply With Quote
Thread Tools
Display Modes
