Old 11-10-2019, 03:09 PM   #21
Werner
Werner's Avatar
Default Re: Analyze this . . .
Dann,
you can also use modern iridium spark plugs (NGK) with adapter. They have a high heat spread. The center electrode is pulled forward and always burns clean. They are a bit more expensive, but you can drive> 50,000 miles.
I take the lowest heat value.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 11-10-2019, 09:22 PM   #22
DannL
DannL's Avatar
Now I am a believer. Put some MMO in the tank for the first time. Perty much felt that I had to do it, with all the recommendations. In less than a mile I could easily see the engine was running smoother. Very interesting . . . indeed. Will check plugs in about 30 miles more.
DannL is offline   Reply With Quote
Old 11-11-2019, 12:38 AM   #23
redmodelt
redmodelt's Avatar
I don't understand why all this fuss about what the plugs look like in 30 miles. Put a set in and drive it. Unless it starts to miss don't mess with them. Put some real miles on them.
Old 11-11-2019, 03:54 AM   #24
DannL
DannL's Avatar
Ibn
Recently, it only took a few miles to foul the plugs to where the car would no longer start. So, just for now, l'm using 30 as a gauge troubleshooting wise. Oh, l would love to just drive . . . . trust me. But having a car that starts when it's needed is also perty handy. :-)
Old 11-11-2019, 10:24 AM   #25
F.M.
Originally Posted by DannL View Post
Ibn Recently, it only took a few miles to foul the plugs to where the car would no longer start. So, just for now, l'm using 30 as a gauge troubleshooting wise. Oh, l would love to just drive . . . . trust me. But having a car that starts when it's needed is also perty handy. :-)
Try looking into your Carb for your problem !!.
F.M. is offline   Reply With Quote
Old 11-11-2019, 11:40 AM   #26
30 Closed Cab PU
For fouling in 30 miles I suspect you may only get marginal improvement with the W18s.
Try the w18s, if issue not resolved as FM indicates most likely your carb is running way too rich. Try cleaning the carb, clean the passages/jets, can replace Jets using Renners Corner Jet kit (they come flow tested). Or if you have or can borrow a known good carb. swap in a different carb.
Old 11-11-2019, 12:05 PM   #27
F.M.
That is exactly what I said in post #2 above !!..
Old 11-11-2019, 12:17 PM   #28
30 Closed Cab PU
Yep, was agreeing with you, a rehash, and adding a suggestion or 2.
Old 11-11-2019, 04:26 PM   #29
F.M.
Yup, You can lead a Horse to water "BUT" !!
Old 11-11-2019, 05:01 PM   #30
DannL
DannL's Avatar
I also would agree had I not recently changed carburators at someones suggestion. This horse can't hardly drink much more water. (Thats meant to be a funny btw.) Nobody has suggested an engine rebuild. I wonder why. ;-)
Old 11-11-2019, 05:29 PM   #31
ETAModel
DannL, I was going to ask how's the compression, and is she using oil? I'm new on here, but the 30 Fordor I'm driving will hit 45mph before you can say Bob's Your Uncle, (as my Brithish cousin says), and tours along at 50 likes its nothing. I actually have to watch my in town driving or I'll get the red/blue light special.
IMHO, the plugs look a little rich, basing this on years of small engines and farm tractor use. I bought a set of hot range plugs for my Farmall, hoping to lease some farm land, but it fell thru. Now i have to clean #3 plug regularly...I should get a new set of plugs.
Good luck, hope the weather is nicer in OKC than here...BRRRRRR!!!
ETAModel is offline   Reply With Quote
Old 11-11-2019, 05:35 PM   #32
wmws
The fact that MMO helped smooth things out leads me to believe part of your trouble is sticking valves. You are running too rich also. Do you have an air cleaner on there especially a paper one?
wmws is offline   Reply With Quote
Old 11-11-2019, 05:36 PM   #33
F.M.
Rebuild the Engine ?? Why,?? Put in the plugs you have been told to and get a GOOD Carburator and drive it all day..
Old 11-12-2019, 11:12 AM   #34
30 Closed Cab PU
So you tried another good carb, no help? Re-read this string and did not see this info.
Perhaps a summary of what has been done would help, if the W18s do not solve your issue.
