07-07-2018, 03:59 PM | #1 |
289 ford flywheel measurement
I'm working on a '65 Mustang 289 cu. in. with my friend. He purchased an after market flywheel and a used 6 bolt bell housing. The car is going to run a borg/warner T10. We mounted the engine on a run stand, installed the starter and tried to start it. The starter spins, the Bendix comes out but misses engaging the flywheel by about 3/4 of an inch to the side of it.
The flywheel is 13 1/4 inch in diameter, is this wrong? Can some one tell me if that measurement is good or not. Or is there another bellhousing that we need for this. Thank You |
07-07-2018, 05:51 PM | #2 | |
Re: 289 ford flywheel measurement
Maybe this will help-
You go with the number of teeth on your ring gear. SOURCE- https://www.cjponyparts.com/flywheel...5-1968/p/MTF1/
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
07-08-2018, 09:30 AM | #3 |
There are two different starters for the small block, one for automatic and one for manual. The manual is 3/8 deep and should have a hole in the block plate about 4 1/8. The auto is 3/4 deep and a hole about 4 1/16. I have just changed the nose of the starters to make it work when I have both.
07-08-2018, 09:37 AM | #4 |
Rereading your post, it sounds to me you have a 164 tooth bellhousing and a 157 tooth flywheel. All the early 289's I played with had the 157 tooth flywheels/ flexplates. Any casting numbers on the bellhousing?
07-08-2018, 03:57 PM | #5 |
Hey Flatrod, I could not find any casting numbers on the bell housing. I'll have to get the engine out of the run stand next weekend and do a tooth count. The bell housing is aluminum, Kultulz says it should be correct for the 157 tooth flywheel. Thank both of You for your help. After I do the tooth count next weekend I'll let you know what I found
07-08-2018, 06:22 PM | #6 |
The old 5-bolt block types were likely a C3 part number and would have had the old narrow Borg Warner pattern like T-85 & early T-10 transmissions had. |
07-09-2018, 04:03 AM | #7 |
Here is some TECH info to help you along-
- http://www.mustangtek.com/sidebyside...wheelsize.html - https://forums.vintage-mustang.com/v...teresting.html
07-09-2018, 10:40 AM | #8 |
Thank You for the help Guys. We located another bell housing and we're swapping it in this coming weekend.
