05-10-2013, 03:10 PM | #1 |
31 roadster starter motor
Heres a question for all you wizards , having a problem tunning over the engine with the starter. engine is out of the car sitting on an engine stand. My objective is to just crank over the engine to watch the valves , pistons , etc. I dont have a 6 volt batt. hooked up , I do have it hooked up to a heavy duty charge/ start charger. all I get is the starter motor spin. so I removed the starter , took out the books and am attempting to fix this myself. The bolts look good the gear spins on the shaft,nothing looks cracked or broken?? Any Ideas out there, would I really need to put a 6 volt batt. in, I thought the 6 volt starter / charger would be enough to engage the starter to the flywheel ???? ANY HELP OUT THERE IS AS ALWAYS GREATLY APPRECIATED THE HOOCH
05-10-2013, 05:55 PM | #2 |
Re: 31 roadster starter motor
Switch your charge/start charger to 12V and try that.
Paul in CT |
05-10-2013, 05:58 PM | #3 |
Sounds like you need more cranking amps Hooch
05-10-2013, 06:03 PM | #4 |
Yes. Either of the above 2 replies, or have you lubricated the bendix threaded shaft. When dry, the small bendix gear does not spin into the ring gear, causing the problem you have. Just a thought.
R.H.D. Author of Model 'A' Ford technical manuals. Supplier of good original RHD parts. |
05-10-2013, 06:12 PM | #5 |
Most people recommend NO lubrication.
Paul in CT |
05-10-2013, 06:22 PM | #6 |
05-10-2013, 10:26 PM | #7 |
Yep, best to connect to a battery, even if it's a junk 6 volt in combination with the charger.
As mentioned, you do need more amps. |
05-11-2013, 01:14 PM | #8 |
Ok Guys got good news , went to a local starter shop just for info. guy was very help ful. Do not use a start/charge by itself, could burn out an electrical component . can use a 12v batt. just for short spins they do it all the time. so i did , starter works fine. thanks for the replys, as a carpenter might say measure twice cut once.. tHANKS ALL , THE HOOCH
