1949 Ford F1 Dana 41 ring and pinion, carrier, spider gears, pinion spacer and shims and driveshaft yoke in excellent used condition. Parts were cleaned in solvent. No broken teeth and did not see any pitting. Good wear pattern on gears. Carrier bearings had very little wear. Oil was clean that came out of rear. 11 tooth pinion and 41 tooth ring gear so I came up with 3.73. 19 spline axle. Hard to find and hard to find one this nice. Willy's and Studebaker also used this rear. Can ship in large flat rate box.
