10-05-2012, 01:02 PM | #1 |
BB crankshaft
i took my BB crankshaft to the auto machine shop, they say that they cannot grind it with the wieghts over lapping the rod jouranls . looking for information about taking the wieghts off and on a BB crankshaft so it can be ground. thanks john
10-05-2012, 01:37 PM | #2 |
Re: BB crankshaft
Take it to a shop that specializes in the old Fords. If you posted your general location and/or included it in your profile someone might have suggestions for a shop.
Charlie Stephens Last edited by Charlie Stephens; 10-07-2012 at 05:17 AM. |
10-05-2012, 01:42 PM | #3 |
Re: BB crankshaft
Drill the pins out and then bump the weights off with a lead hammer.
We used to do a lot of them when we had a crank grinder. We used to put the weights back on with screws so it was easier to do the next time. |
10-06-2012, 12:01 AM | #4 |
Re: BB crankshaft
I thought that I read somewhere that some of those B cranks with pinned-on weights were "for industrial use only" and would not stand up to the high-revs that they would get in a car/pickup. if that is true, how do you know what B crankshafts with pinned on weights are OK to use?
10-06-2012, 03:45 AM | #5 |
Re: BB crankshaft
The pinned on weights have a full circle, so they are plenty safe for your car.
10-06-2012, 11:34 AM | #6 | |
Re: BB crankshaft
Here is a pic of the bottom end of my last engine. It turned 6100 twice a lap for 2 seasons and then was sold and put in a vintage dragster and won the Antique Nationals 2 years in a row. |
10-06-2012, 02:52 PM | #7 |
Re: BB crankshaft
That is a thing of beauty!!
10-07-2012, 02:25 PM | #8 |
Re: BB crankshaft
A welder friend of mine welds a stick to the pins and pulls them out. He then knocks the weights over just far enough to clear the grinding wheel. He then knocks them back in place and has the mains ground (or vice-versa?) I have seen those weights come off of race engines but are fine for normal use. An engine builder in Texas says that he has never seen a BB crank with a crack in it.
10-07-2012, 04:01 PM | #9 |
Re: BB crankshaft
We shrink ours weights on, they would never need the pins to hold them, but we put them in any way.
Herm. |
10-08-2012, 10:24 AM | #10 |
Re: BB crankshaft
how did you shrink the weights on . at one time did they have offset stones to grind these crankshafts . when was the bb crankshaft introduced , were they for industurial use . john
10-08-2012, 08:03 PM | #11 |
Re: BB crankshaft
Maybe this might help understand
10-08-2012, 10:44 PM | #12 | |
Re: BB crankshaft
The off set stones, and Machine that I seen, was made by Sunnen, and was made for a single rod pin, and also they came out with the longer stone on one side. Herm. |
10-09-2012, 10:37 AM | #13 |
Re: BB crankshaft
Sure like to see a picture of that !
