11-03-2018, 06:30 PM | #1 |
Rear Motor Mount Outer Plate
Were the steel outer plates ever dimpled around the holes or is this the result of 80+ years of wear? The dimple is deep enough that when the castle nut is tight, it's past the cross drilled hole in the bolt. Adding a flat washer causes the opposite problem. Thinking about just using nyloc nuts.
11-03-2018, 07:20 PM | #2 |
Re: Rear Motor Mount Outer Plate
Looks like wear. You could flip them over and have a new flat surface, as long as the steel spacers don't then sink into the worn area.
11-03-2018, 08:06 PM | #3 |
11-04-2018, 04:22 PM | #4 |
