Old 01-17-2020, 10:20 PM   #1
Clem Clement
Clem Clement's Avatar
Default ground strap for car.
Back in the 50'a we used to see aftermarket ground straps for cars. Were they just some old wire hung from a frame or a commercially made clamp/wire/spring, etc.?
Clem Clement is offline   Reply With Quote
Old 01-17-2020, 10:51 PM   #2
JSeery
JSeery's Avatar
Default Re: ground strap for car.
You could purchase them.
Old 01-17-2020, 11:48 PM   #3
petehoovie
petehoovie's Avatar
Is this what you're asking about? > http://mizter.com/car-antistatic-gro...p-assembly.htm
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 01-18-2020, 05:48 AM   #4
PeteVS
PeteVS's Avatar
I recall that petroleum tanker trucks had a length of chain hanging long enough to touch the ground.
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 01-18-2020, 06:52 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
Yes, you could use just a wire but it has to be flexible enough to change direction when driving in reverse.
In my case I fabricated my own out of i/8 inch braided cable bolted to the frame.
Or you can purchase the same type rubber ones used back when, such as these on Ebay.
https://www.ebay.com/itm/1-1-6x25-Ga...MAAOSwo~dcgpxL
Amazon also has 'static straps'
Old 01-18-2020, 09:09 AM   #6
corvette8n
corvette8n's Avatar
I've seen them for sale at the bigger truck stops on the interstate.
Old 01-18-2020, 10:21 AM   #7
19Fordy
19Fordy's Avatar
Can you use an old fan or serpentine belt to make your own?
Old 01-18-2020, 10:41 AM   #8
51 MERC-CT
51 MERC-CT's Avatar
Supposedly the ones made for the purpose are made up from a special rubber compound that attracts and promotes the discharge of static electricity also don't have any internal threads.
Old 01-18-2020, 12:57 PM   #9
JayChicago
JayChicago's Avatar
Seems like a static strap would have to be able to conduct electricity. Maybe these rubber static straps have embedded fine metal conductors on the outside faces?
JayChicago is offline   Reply With Quote
Old 01-18-2020, 04:28 PM   #10
19Fordy
19Fordy's Avatar
Just for the fun of it, here's another static electricity car part.
https://www.fordbarn.com/forum/showt...ectricity+part
Old 01-18-2020, 05:11 PM   #11
51 MERC-CT
51 MERC-CT's Avatar
I installed static straps on my car not to prevent shocks or eliminate radio noise but to reduce the airborne dust that is being attracted and deposited on the car body. (It has significantly reduced the dust)
Old 01-18-2020, 10:00 PM   #12
Clem Clement
thanks all. Most interesting. If you were a cool dude, weren't dual straps in style?
Old 01-18-2020, 10:09 PM   #13
Brian
Brian's Avatar
I run one of those rubber ones on my 35. I have a daughter who, every time she alighted the car, would get a shock.
One old guy told me that the head mounted water pumps act like little turbines, producing electricity, eating out the aluminum heads. Indeed, one of the major electrolysis eaten places in those heads is around the pump mount flanges. As I'm all for doing anything I can to preserve the aluminum heads, I run earth straps everywhere. Certainly can't hurt!
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
