Old 07-20-2016, 06:01 AM   #1
Wareagle
Wareagle's Avatar
Default eccentric rivet installation
Quick question here. Can't seem to find anything on the proper way to install the eccentric rivet in the steering box. Does the high point of the rivet go up or down? Found nothing in the service bulletins or the red book. Thanks for the help.
Jim
Jim P.
central Ohio
1930 Tudor Sedan
15 grandchildren and 2 great grandchildren
and loving it!!
Wareagle is offline   Reply With Quote
Old 07-20-2016, 07:49 AM   #2
Kevin in NJ
Default Re: eccentric rivet installation
I think I inferred the direction from the picture in the service bulletins.
But I can not remember which way it was. I am thinking away from the gear, the idea is all new parts would be further away. With wear the plate would need to be closer to the worm.
In any event, the distance has to be where the sector is tight to the worm when central.
Kevin in NJ is offline   Reply With Quote
Old 07-20-2016, 12:50 PM   #3
Rip
Rip's Avatar
Think Les red book page 1-302 and called centralization rivet. That's the only test/adjustment I have not tried for solving the right slop in my steering wheel drive straight down the road. Not even sure what it does. Mind failing🤔
Rip is offline   Reply With Quote
Old 07-20-2016, 01:04 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by Rip View Post
Think Les red book page 1-302 and called centralization rivet. That's the only test/adjustment I have not tried for solving the right slop in my steering wheel drive straight down the road. Not even sure what it does. Mind failing��
When you are driving straight down the road you want the steering gear to be exactly centered, that is when you can turn the steering wheel an equal amount to lock it going right or left of center. The steering gear is made to be tightest in the center and a slight bit looser off center. Follow the SERVICE BULLETINS and you'll get it right.
Old 07-20-2016, 02:56 PM   #5
Joe K
Joe K's Avatar
I think the "centralization rivet" can go either way as you're adjusting left-right as you look at it. Just as the eccentric can go either way left to right. (in-out for that one a different matter.)
Follow the service bulletins. A job best done with the steering column OUT of the car and held by a vise.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
