09-01-2020, 06:59 PM | #1 |
Speedometer Cable Length
I'm adding an overdrive transmission to my '51 Crestliner. Any idea if the speedometer cable length changes between the standard three-speed gearbox and the overdrive unit? It looks like the port on the OD transmission is a bit further back than on the standard one, but it also looks like there might be enough slack in the cable to work. Any idea?
09-01-2020, 07:17 PM | #2 |
Re: Speedometer Cable Length
parts book says for a 51 speedometer cable is 70 3/4" parts # 1A 17260-A replaced by part # BPA 17260-A for both 3 speed and overdrive
09-01-2020, 07:18 PM | #3 |
Not Ford but Mercury in '51 shows the OD application to be 7" longer than three speed.
09-02-2020, 08:56 AM | #4 |
09-02-2020, 09:12 AM | #5 |
cable Also that the 49-50 take a 69" cable the wagon takes a 79" cable and the 49-50 with overdrive takes a 79" cable |
