Old 09-01-2020, 06:59 PM   #1
Admiral
Admiral's Avatar
Default Speedometer Cable Length
I'm adding an overdrive transmission to my '51 Crestliner. Any idea if the speedometer cable length changes between the standard three-speed gearbox and the overdrive unit? It looks like the port on the OD transmission is a bit further back than on the standard one, but it also looks like there might be enough slack in the cable to work. Any idea?
Eight cylinders, four doors, three speeds, one good time
Admiral is offline   Reply With Quote
Old 09-01-2020, 07:17 PM   #2
Wayne Schuenke
Default Re: Speedometer Cable Length
parts book says for a 51 speedometer cable is 70 3/4" parts # 1A 17260-A replaced by part # BPA 17260-A for both 3 speed and overdrive
Wayne Schuenke is offline   Reply With Quote
Old 09-01-2020, 07:18 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
Not Ford but Mercury in '51 shows the OD application to be 7" longer than three speed.
Old 09-02-2020, 08:56 AM   #4
Admiral
Admiral's Avatar
Interesting... The book doesn't list any other lengths, does it? If not, it would seem OD and non-OD transmissions use use the same cable.
Old 09-02-2020, 09:12 AM   #5
Wayne Schuenke
Yes it does it also states that the 51-52 with a fordomatic takes a 80 3/4 " speedometer
cable Also that the 49-50 take a 69" cable the wagon takes a 79" cable and the 49-50 with overdrive takes a 79" cable
