09-03-2018, 03:46 PM | #21 | |
Re: Lockheed brake frustrations
09-03-2018, 03:51 PM | #22 | |
09-03-2018, 04:09 PM | #23 |
Along this same line of brake questions, I have a '36 with manual brakes. I have acquired a complete '39 front end and will be putting the Bendix backing plates on it. for the rear end, I have a set of '39 rear backing plates and the emergency brake cable set up.
Question is, will I need to do any centering when mounting the '39 plates on the '36 rear end? |
09-03-2018, 04:57 PM | #24 | |
09-03-2018, 05:41 PM | #25 |
Sorry, I could not see my initial posting, now I can figure out how to delete this one.
09-03-2018, 06:36 PM | #26 |
09-03-2018, 07:30 PM | #27 |
I take a piece of 80 grit sticky back sand paper made for the air file and stick it the the inside of the drum then with the shoe in hand dust the lining surface with black paint. Then work the shoe back and forth in the drum. You will see immediately that the shoe isn't making full contact. Keep working it untill it does. Yes it's time consuming but it's always worked for me. My 40 will slide the tires.
09-03-2018, 08:12 PM | #28 | |
Big project comming up. I will have it stopping well when I am done. Photo from 1969. |
09-04-2018, 01:35 AM | #29 | |
Alan |
09-04-2018, 02:51 AM | #30 |
MT puts out a nice set up! I got rid of the old system and now I can stop!!
09-04-2018, 08:15 AM | #31 |
Do you still have the Wide 5 wheels? I know that disc all the way around are available for the standard 5 on 5 wheels.
09-04-2018, 10:16 AM | #32 |
09-04-2018, 02:10 PM | #33 |
I'm just hoping Flathead Ted will soon release a Lockheed floater kit after he's done testing his prototypes. Jack E/NJ
09-04-2018, 02:50 PM | #34 |
Bill: How old are the hoses??
Paul in CT |
09-04-2018, 03:42 PM | #35 |
I dont know when they were changed last, Paul, but they look fairly new. I am planning a complert overhaul of the brakes in a few weeks, so time will tell.
09-04-2018, 06:46 PM | #36 |
If you use the original Lockheed brakes, replace the lining with NOS ones. Fred Wilner at SSO in MN, Nelson Pease, Pease Antique Parts in Palmer MA, and Ray Helgers in RI will likely have the good old linings. Ray's son, Ray III told about a '40 he put new brakes in and it wouldn't stop worth a darn. It wouldn't even lock up the wheels. Ray got a set of NOS ones from his dad's NOS parts, put them in, and it stopped like it should, and locked up the wheels when he got on it hard.
09-05-2018, 11:08 AM | #37 | |
