01-15-2019, 05:31 PM | #1 |
1934 picku cab wood and seat
I thought that resurrecting this thread might be better than me starting a new one. Lots of good info already posted here.
I posted this on another older thread but not getting any traction, so I'm starting a new thread. My 34 has some original, some reproduction and a lot of poorly homemade cobble-up and I have no idea what the original should be like. I have a good friend who has a mostly original 32 pickup but the info I gleaned so far leads me to believe that the 2 model years were very different from the factory. My seat cushions are both new...new springs, new wood, new fabric. I am assuming that they are correct for 1934. Bottom cushion has a tag (pic). But there are NO brackets or whatever to hold the back in place. Unclebucks has 'S' shaped sheetmetal brackets which are screwed to the seat back at the top and to the cab wood. The frame of my backrest cushion has no wood to attach such a bracket. Also, is there another bracket(s) to hold the lower part of the backrest in place? |
01-15-2019, 07:57 PM | #2 |
Re: 1934 picku cab wood and seat
As you said, I'm sure '32s are quite different. But I thought I'd upload a couple of pics of my Open Cab '32 pickup that shows the rear wood slats. I don't know if Closed Cab 32s are the same.
My three slats are full length, and each has a pointed bracket down low that catches the rear edge of the backrest wire frame. It looks like your middle slat has 2 holes in it, but can't quite tell. I believe the top of my backrest is supposed to have the fabric (vinyl) stretched and tacked to the wood frame around the rear of the cab. In other words, once in place it's not removable. My original and replacement springs for both seat and backrest were a match. No wood frame on the backrest--just the wire frame. Not sure this helps, but maybe provides a little more knowledge.
1932 Model B Roadster Pickup |
01-15-2019, 10:16 PM | #3 |
I get my wood from Brads Wood Shop. 360-317-5723. He did the wood for my 32 pu and it fit perfect. The wood for the 34 is different because of the added body bead around the back. 32 and 33 wood is basically the same. Brad usually spends the winter somewhere south where it's warm and returns north to his shop in the spring. I did get wood for one of my 32 pickups from Mac Hills in MO and some of the holes in the wood did not line up with the holes in the body.
01-16-2019, 06:23 PM | #4 |
On my 34, there are some metal attachments screwed to the wood in the back of the cab, just like rbullocks'. You slide the back seat cushion down over these catches and it retains the seat back. The bottom cushion is only retained by the two protruding bumps at the corner of the seat mounting pedestal which go up into holes drilled into the bottom cushion wood frame. You slide the bottom cushion under the back cushion and secure the bottom into the two spring loaded bumps on the seat frame. Probably not the safest way to mount a seat, but thats the way mine came and it was pretty original when I got it.
Matt 24:36-41 |
01-17-2019, 01:54 PM | #5 |
I don't have my truck at home.
The wood pieces in the cab do have the V-shaped holders for the bottom of the seat back. Also there is a metal strap that projects above the top of the seat back. I don't know if it attached to wood on the seat back or metal. It is about 3/4" wide and 2" above the back. One screw goes into the wood in the cab, and keeps it in place. The frame on my seat bottom is metal. Hope this helps, Byron.
IT'S NOT YOUR AGE, IT'S YOUR ATTITUDE ! |
01-17-2019, 03:18 PM | #6 |
This is a great discussion since I am just getting started working on my Grandfather's 34 pickup I inherited 25 years ago. Thanks for all the great information. Cheers, Jim |
01-17-2019, 04:42 PM | #7 |
Has to be a '33 cab as there is no separate "metal seat bottom frame" in a '32 cab as the bottom cushions (two separate ones) fit on top of the fuel tank. Also, the odds are very high that your firewall is not detachable from the rest of cab, unlike in a '32 cab.
01-18-2019, 01:05 AM | #8 |
GearheadBill, it appears the shortest uprights have been cut off. There should be a rectangle hole with a tab in floor. That tab has a hole in it to screw to the bottom of wood. rbullockv8 shows the correct pointed brackets although his is RPU. It seems rather barbaric to stick those pointed brackets through the upholstery. At the top of seat back were a formed metal loop that screwed to wood (next to window) after skewering on pointed brackets. I think I see stripped out holes in your wood.
01-18-2019, 04:08 PM | #9 | |
Thanks a bunch, this is very helpful. |
01-18-2019, 08:43 PM | #10 |
If the firewall isn't removable because its spot welded in place and the back of the cab has two stamped-in horizontal moldings like in the photo below, it's a '33. If it has three stamped-in horizontal belt moldings in the back, it's a '34. (That is not to say your cab has been changed as the transition from the '33 model year to the '34 model year was blurred and it would not be remarkable that a early '34 pickup was built with what is thought of as a '33 cab.)
01-22-2019, 04:43 PM | #11 | |
20190122_132707s.jpg 20190122_132801s.jpgThanks so much for your help on this. |
01-22-2019, 07:17 PM | #12 |
Nope, two moldings, not three. It's what would normally be thought of as a '33 cab. See the photos in the opening of this thread. While taken inside, you can count three indentations. If you had those three they would show up very prominently on the corners of the cab.
01-23-2019, 03:10 PM | #13 |
Thanks DavidG. I really appreciate your patience and expertise!
