Old 01-22-2019, 10:21 AM   #1
russcc
Default Vacuum question
Took a 2 bolt timing cover of a 59 engine. The distributor was a 21A, crab. The 59 had double sheave water pumps so I assume it may be a truck engine. In the vacuum inlet on the timing cover was a brass plug with a washer. See photo.
What would be the purpose of blocking off the source for vacuum to the distributor brake ?
russcc is offline   Reply With Quote
Old 01-22-2019, 10:47 AM   #2
flatjack9
flatjack9's Avatar
Default Re: Vacuum question
Ignorance?
Old 01-22-2019, 11:01 AM   #3
bitterbierce
bitterbierce's Avatar
Just guessing but perhaps it was a stationary engine before and someone thought advance was no longer needed (big mistake)
bitterbierce is offline   Reply With Quote
Old 01-22-2019, 02:52 PM   #4
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Originally Posted by flatjack9 View Post
Ignorance?
Didnt want to have a vacuum leak ?????
If it Makes Spark, we do it !!!!
www.bubbasignition.com
jimlinder@juno.com
BUBBAS IGNITION is offline   Reply With Quote
Old 01-22-2019, 06:33 PM   #5
flatjack9
flatjack9's Avatar
I assume that's a joke.
Old 01-22-2019, 06:35 PM   #6
Flathead Fever
Flathead Fever's Avatar
Maybe some one stuck an old go-fast distributor or maagneto on there with no vacuum advance
Flathead Fever is offline   Reply With Quote
Old 01-23-2019, 07:06 AM   #7
russcc
It looked all original when I got it, including the 21A distributor. Doesn't sound like there was a logical answer. The engine came form Maine if that means anything
Old 01-23-2019, 05:17 PM   #8
BUBBAS IGNITION
Yes it was " Bubba" humor. I get them in all the time with the vacuum port on the distributor plugged with something ...........
jimlinder@juno.com
Old 01-24-2019, 05:21 PM   #9
russcc
Then that's the answer, common ignorance.
Old 01-26-2019, 12:00 PM   #10
V12Bill
V12Bill's Avatar
Plug looks like the access to the carb jets.
V12Bill is offline   Reply With Quote
Thread Tools
Display Modes
