Old 11-26-2017, 06:47 PM   #1
burner31
burner31's Avatar
Default Winter car work 2017
Took my car off the road Nov. 6TH. Here's my Winter work list.
Some things are done, (been real busy), some things are in process - I/P, and some things are left to do.
Sure I'll be adding things along the way.
Hope to have the list complete by 1st day of spring 2018 (March 20th)
What's on your list?
DONE-Rebuild Horn, rewire horn rod, install horn relay, install horn
DONE-Repair speedometer
DONE-Re-route headlight conduit/wires
DONE-Install original dash light
DONE-Install new seat sliders
DONE-Weld seat frame, clean/prime seat frame
DONE-Install luggage rack
DONE-Change dash wiring
DONE-Adjust doors RF. LF, RR, LR
DONE-Weather strip doors LF, RF, LR, RR
DONE-Cut off door striker plates RF. RR
DONE-Install new striker plates RF. RR
I/P-Install engine pans, paint pans
I/P-Rebuild steering box
I/P-Re-paint steering wheel
Front end alignment
Lube regulators, LF, RF, LR, RR, L/quart, R/quart
Install lower door seals RF. LF, RR, LR
I/P-Install running board mats
Install insulation
Install rear window block
Install rear seat blocks
Change water neck
Re-torque head
Install water pump thrust washer
Install ID plate
Install seat belts, front/rear
Install new door panels LF, RF, LR, RR
Adjust brakes, LF, RF, LR, RR
I/P-Install brake anti-rattle LF, RF, LR, RR
Lube wheel bearings, LF, RF, LR, RR *Rotate tires
I/P-Install tranny re-fill tube
Cut tranny access hole/install cover plate
Drain/flush/refill tranny
Drain/flush/refill rear end
Oil change
WASH CAR...DRIVE AS NEEDED
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 11-26-2017, 06:59 PM   #2
WHN
Default Re: Winter car work 2017
My!
To be young again. Enjoy.
WHN is offline   Reply With Quote
Old 11-26-2017, 07:22 PM   #3
aford193031
aford193031's Avatar
I agree with that "to be young again"
aford193031 is offline   Reply With Quote
Old 11-26-2017, 08:45 PM   #4
burner31
burner31's Avatar
Young?
1st time I got puking, falling down drunk was New Year's 1960
If you keep moving, it makes it harder for age to catch up.
File Type: jpeg 7bf20e311716c9f6f50cd81baf7a91e6_400x400.jpeg (18.1 KB, 10 views)
Keith
Shawnee OK
'31 SW 160-B
Old 11-26-2017, 09:40 PM   #5
Larry Jenkins
When you get my age, 86, it would take you 152 years to complete..
Nicely organized.
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 11-26-2017, 10:57 PM   #6
Railcarmover
Railcarmover's Avatar
Rip it all apart, chop the top off, lose interest and leave it out in the rain..no wait, this isn't a hotrod forum is it..Nah...engine build ongoing, here's the fifty cent static balance of half the rotating group
Nice block sleeved and exhaust seats,babbit fresh. finish it and the chassis by spring..should be a piece of cake, A true model a guy, the late Dick Wolpert built this chassis, though he is gone the quality of his work endures
Railcarmover is offline   Reply With Quote
Old 11-27-2017, 01:21 PM   #7
burner31
burner31's Avatar
Fixed it for you
Keith
Shawnee OK
'31 SW 160-B
Old 11-27-2017, 02:37 PM   #8
Railcarmover
Originally Posted by burner31 View Post
Fixed it for you
thanks, it sucks picking up the monitor and turning it..btw aint you supposed to be doing winter work? cant get nothing done diddling on the inerwebs
Old 11-30-2017, 10:07 AM   #9
burner31
burner31's Avatar
A man has to eat.
Have to slow down on my "Winter work" thou, my regular job is busy, busy.
No days off for the next two weeks. Damn.
Keith
Shawnee OK
'31 SW 160-B
Thread Tools
Display Modes
