01-01-2019, 09:29 PM | #1 |
8CM to 8BA
Hey fellas,
So the 51 merc 8CM is shot and needs to be rebuilt good news is I have a 8BA rebuilt motor in the garage and was thinking about just swapping parts and running it Instead. ( yes I know I should rebuild the 8CM, but I don’t want to spend the money ) with that said I remember reading that the 8CM and the 8BA are the same blocks so everything such as the intake, heads, water pumps, oil pan, bell housing, and crank pulley all from the 8CM fit the 8BA? Any wisdom would be greatly appreciated. Thanks! |
01-01-2019, 10:06 PM | #2 |
Re: 8CM to 8BA
If you could use the crank, it makes a huge difference in torque(hill climbing and pulling power). Just my .02
01-01-2019, 10:24 PM | #3 |
Re: 8CM to 8BA
Water Pumps are different on the 8CM.
01-01-2019, 10:43 PM | #4 |
Re: 8CM to 8BA
Will they fit on the 8BA?
01-01-2019, 10:44 PM | #5 |
Re: 8CM to 8BA
If you have a completely assembled, rebuilt 8BA , to me the only thing most necessary to swap would be the water pumps that fit the 8BA and if you find it really necessary the intake to run the original carb.
To swap the heads would be a waste of time and if you don't like looking at the 8BA on the heads just grind them off.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 01-01-2019 at 10:49 PM. |
01-02-2019, 02:29 AM | #6 |
Re: 8CM to 8BA
01-02-2019, 12:16 PM | #7 |
Re: 8CM to 8BA
Thanks guys! Anyone else with any incite?
01-02-2019, 01:39 PM | #8 |
Re: 8CM to 8BA
If you are putting it in a 51 Merc you can swap parts as needed but you will probably miss that extra stroke crank in the 8CM.
01-02-2019, 02:39 PM | #9 |
Re: 8CM to 8BA
The blocks are identical, so everything that bolts on can be swapped over.
I'd put the Merc crankshaft and connecting rods in, together with a new set of pistons and rings, and have a nice 255 again. |
01-02-2019, 03:04 PM | #10 |
Re: 8CM to 8BA
I think you will need to install the Merc rear sump oil pan in order to clear merc steering linkage.
01-02-2019, 03:39 PM | #11 |
Re: 8CM to 8BA
If your not going to use the longer stroke crank then you may want to look for some EAB heads from 52/53 Ford to increase the performance a bit. Mercs are heavier than shoe boxes so any extra power is nice. A 239 will get better performance with those heads.
After you run it a while, you will likely want to rebuild the 255 and put it back in there. A Merc just ain't quite a Merc without the 255 crank & pistons but it's your car man. |
01-03-2019, 07:05 PM | #12 |
Re: 8CM to 8BA
I have heard before on this forum that putting 8CM heads on an 8BA motor will lower the compression ratio. So seems like keeping the 8BA heads on your rebuilt 8BA would make sense.
Sal |
01-04-2019, 08:27 AM | #13 |
Re: 8CM to 8BA
That's true. I even considered putting a set of 8BA heads on my 8CM, but then I'd lose my 8CM markings that I'm so proud of.....
01-04-2019, 09:59 AM | #14 |
Re: 8CM to 8BA
I went the other way and put a '51 Mercury engine in my '51 Ford. I used the Ford bellhousing, flywheel, clutch, water pumps, and oil pan on the Merc engine. I don't remember changing the oil pump pickup, but it should be obvious with both engines open. There were no problems at all; everything bolted together as it should. Going the other way should be just as simple, but probably not as satisfying.
I would have used the 8BA heads except that I already had a carefully prepared set of Edmunds finned aluminum units. |
01-05-2019, 10:57 PM | #15 | |
Re: 8CM to 8BA
The only thing I’m still wonder is if the crank pulley will fit. They are two different size belts so it does need to change. |
01-06-2019, 08:02 PM | #16 | ||
Re: 8CM to 8BA
01-06-2019, 01:25 AM | #17 |
Re: 8CM to 8BA
You should have no problem with the crank pulleys as the crankshafts snouts are all the same. One piece of advice I can offer is to be careful removing cast crankshaft pulleys as they are kind of fragile and can be easily broken during removal. Ask me how I know.
01-06-2019, 07:50 AM | #18 |
Re: 8CM to 8BA
On this same topic, are the fuel pumps different between the Merc and Ford versions?
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
01-06-2019, 08:22 AM | #19 |
Re: 8CM to 8BA
Both the Ford and Mercury can use the same type 'Double pumper' and 'Single pumper' fuel pumps, just a matter of preference.
01-06-2019, 08:35 AM | #20 |
Re: 8CM to 8BA
The only difference between these two engines is internal.
