Old 07-19-2019, 08:06 PM   #1
Don
Don's Avatar
Default Sun machine power supply
I have a older sun machine that uses a 6 volt battery,,,,I donít use the dwell or rpm gauges as I have a external dwell and rpm meter,, would like to rig up a PS to eliminate the battery,,anyone have a drawing that might work
If I knew the amp draw would help,,, Tks
DON P
Don is offline   Reply With Quote
Old 07-19-2019, 08:44 PM   #2
fordwife
Default Re: Sun machine power supply
Google Paramount distributor co. They might be able to help you
fordwife is offline   Reply With Quote
Old 07-19-2019, 09:10 PM   #3
petehoovie
petehoovie's Avatar
Good read for you > http://bambam.gmu.edu/sun/index_files/Page2850.htm
and > http://bambam.gmu.edu/sun/index.htm
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers! Damn!"
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 07-19-2019, 10:51 PM   #4
Pete
Pete's Avatar
If the battery powers the motor, it is going to take a bigger power supply than for just running the rest of the machine. For the motor the supply has to be able to handle the inrush current which can be several times the running current.
You can get a 0 to 30 volt, REGULATED, variable, 20 amp, DC power supply off eBay for about $100.
Battery chargers are not usually regulated so the voltage can vary widely.
Old 07-20-2019, 04:46 AM   #5
marko39
The battery does not power the motor, it is 120volts. If it a Dist. Tester with vacuum tester the battery for one powers the vac. motor. I have not seen a way to eliminate the 6volt battery, only the 2 1.5 volt flashlight batterys for the dwell meter.
marko39 is offline   Reply With Quote
Old 07-20-2019, 09:47 AM   #6
Bob C
Pete,can you post a link to the power supply, I can't find anything over
10 amps in the $100 dollar price range.
Bob
Old 07-20-2019, 11:19 AM   #7
Pete
Pete's Avatar
Bob
There were several used ones a couple months ago but the only one I see now is a new one for 145.
eBay item number:112992679653
Check the vacuum motor plate. 10A may be enough.
Old 07-20-2019, 11:33 AM   #8
marko39
You can trace the wiring from the battery cables to see what else is powered by 6 volt DC.
Old 07-20-2019, 03:06 PM   #9
Terranova
Can I buy the dwell/rpm gauge? The needle fell off my rpm gauge
Terranova is offline   Reply With Quote
Old 07-21-2019, 08:19 AM   #10
alanwoodieman
I also have an older Sun machine and in asking questions about repair, I was told of some one near Charlotte, NC does this. I have not located him yet. Does anyone have that info?
alanwoodieman is offline   Reply With Quote
Old 07-21-2019, 08:51 AM   #11
Hoop
Hoop's Avatar
Alan, last contact I had was for Dave, dcwager@gmail.com. Let us know if that email works.
He is in the Charlotte area and, I believe, worked directly for Sun as a tech.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 07-21-2019, 08:43 PM   #12
Don
Don's Avatar
Need to keep machine all togeather might get it all working sometime,
Got a 6 volt battery now,,I’ll hook up and see what amp draw is ,might tell me which way to go,,
DON P
Thread Tools
Display Modes
