08-22-2019, 11:29 AM | #1 |
Power steering setup
Will a complete power steering setup from a 55-56 T-Bird fit into a full size 1955 ford sedan ?
08-22-2019, 12:47 PM | #2 |
Re: Power steering setup
It looks like the front track width isn't the same.
And I know the brackets that hold the PS pump onto the waterpump & head are not the same. Although the T-Bird brackets may(?) fit in a full-sized car, but not the other way. The T-Bird idler arm for PS and its mounting bracket to the frame are not the same as the manual versions, I suspect the pitman arm is different as well. Those parts in a full-sized '55 Ford likely have a similar difference (PS vs. non-PS). These two links say the '55 & '56 T-Bird front tread width is 56 inches ('57 Bird is the same) http://automotivemileposts.com/tbird/prod1955tbird.html http://automotivemileposts.com/tbird/prod1956tbird.html This link for a '55 Fairlane shows the front track width is 58 inches. https://www.conceptcarz.com/s2073/ford-fairlane.aspx . Last edited by dmsfrr; 08-25-2019 at 11:12 AM. |
08-22-2019, 04:12 PM | #3 |
Thanks for the info...
08-22-2019, 07:01 PM | #4 |
As far as the overall width, you could use your original manual steering tie-rod arms, sleeves and ends on the T-bird steering sector-to-idler arm rod as they might be longer than the T-Bird tie-rod arms. I will post length of one of these arms later.
There is no difference between the full-size car tie-rod arms regardless of whether the car had power steering or not. Just not sure if T-Bird had different ones. I do know that the Mercury full-size car tie-rod arms will not work on a Ford steering system. Not sure why the power steering brackets from the T-Bird wont work on a full-size Ford. May have something to do with the different power steering pulley on the crankshaft damper on T-Birds being closer to the radiator, which means the power steering belt would not line up. I don't think you can use the T-Bird crankshaft damper on a full-size Ford anyway, can you? Something to consider. You can buy a new idler arm and bushings from one of the repro parts suppliers, but the idler arm bracket from the T-Bird won't work on a full-size frame. I think I got an extra sector arm out there too that I could measure so you can compare it with the T-Bird arm. |
08-22-2019, 08:49 PM | #5 |
Is there a company that sells a complete power steering system for a full size Ford using new components ?
08-22-2019, 11:24 PM | #6 | |
Yes, the belts & pulleys on the front of the T-Bird engine are a bit farther forward than in a full-sized car. There is a 1 inch spacer between the timing cover and waterpump on a '55/'57 Bird, and the longer crank damper pulley. |
08-23-2019, 05:04 AM | #7 |
larrys t bird did but pricey havent checked lately.
08-23-2019, 07:50 AM | #8 |
I have looked into electric power steering, simple set up no belts pulleys the unit is
hidden under the dash, only problem is, it is 12 volts. sam |
08-23-2019, 08:06 AM | #9 | |
Yes, Borgeson. Their kit is complete, need to modify the steering column to take a rag joint or coupler. It is as close to bolt-in as there is on the market.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
08-29-2019, 04:02 AM | #10 |
Does Borgeson make a kit for the baby birds also??
08-29-2019, 08:07 AM | #11 |
