Old 08-03-2019, 02:21 PM   #21
51 MERC-CT
51 MERC-CT's Avatar
Default Re: adjustable lifters
Originally Posted by frnkeore View Post
Ok, another question. There are lifters advertised as "Isky Lifters", are these HI Lift Johnson's or off shore? Isky has always had a excellent reputation.
Frank
The "Isky lifters" being sold using their own part number appear to be solid HI Lift Johnson's but you would have to contact Iskenderian or the seller to get that info for sure.
Old 08-03-2019, 08:40 PM   #22
Pete
Pete's Avatar
Originally Posted by 51 MERC-CT View Post
This is an example of a fake Johnson hollow lifter.
Lifters are not radiused on the face. They are TAPERED.
Aside from that, the fake lifters can be refaced properly and the screws can be re-machined so they stay put, BUT, do you want to take a chance on the material they are made from?
No one seems to know what that is. Is it virgin cast iron that has the face only induction hardened, or are they made from old melted down cast iron sewer pipe and old sash weights????
If you absolutely have to have adjustable lifters, go with the heavy USA made ones. They are fine for stock and mild street engines.
Old 08-03-2019, 08:47 PM   #23
Robin 47 ford pickup
Ok the auction # on Evilbay was 372718954599 under, Ford flathead 8BA 21A 21 stud hollow adjustable tappet lifter mercury Johnson description and read the info & look at the sold listings.
let me know what you all think?
cheers Robin
Robin 47 ford pickup is offline   Reply With Quote
Old 08-03-2019, 09:36 PM   #24
51 MERC-CT
51 MERC-CT's Avatar
cheers Robin
Those hollow lifters are the same ones that are being referred to in the letter in post #11 above.(suggest that you read it) They are not Hi Lift Johnson nor does the listing in Ebay say that they are.
Old 08-03-2019, 10:11 PM   #25
34PKUP
34PKUP's Avatar
Hi Lift Johnson calls it a "Camface Crown"
34PKUP is offline   Reply With Quote
Old 08-03-2019, 10:21 PM   #26
Pete
Pete's Avatar
They are free to call it anything they want but it is still a taper, which makes the surface cone shaped.
Old 08-04-2019, 12:09 AM   #27
clo
Red’s headers sells the adjustable hollow lifters. I’ve spoken to quite a few Flathead guys that use them. I haven’t heard anything negative like the lifters loosening up.
clo is offline   Reply With Quote
Old 08-04-2019, 08:50 PM   #28
Ok , what is the chance they are any good, and i see they have sold quite a few sets now, and there is no negative feedback .My big question still remains has anyone used or know of anyone that has bought these lifters ?
Old 08-05-2019, 09:40 AM   #29
Ol' Ron
Ol' Ron's Avatar
Trust is always an issue. We all like to save money, and building a flathead is getting expensive, so you have to go with the people that build engines loke Gary (gofast) Or Reds they have the "right stuff" Not sure if Nax VP has them. but they are in business to help people and stand behind their products. IMHO
Old 08-05-2019, 01:49 PM   #30
Pete
Pete's Avatar
I was wrong on that. They do have grinders capable of grinding a sphere.
While most of their lifters seem to work, that is the WRONG way to do it.
With a sphere, you have single POINT contact instead of flat line contact resulting in much higher unit pressure.
Isky found out early on that a spherical surface had very poor wear characteristics. With a race cam they did not last to the main event.
